It is currently Fri Jul 04, 2025 10:24 am
Reply to topic  [ 14 posts ]
 Performance problem - 18x48 w/ 37EFI
Post Performance problem - 18x48 w/ 37EFI
I have a new 1848 custom made duck boat with a new MudBuddy 37EFI HDR. By all accounts, the boat should be able to hit 30mph with a moderate load but the best I can do is 25mph. It gets up on plane easily and turns 4500 RPM with no problem. As I trim the prop lower into the water, the best speed I can attain is 25mph but the RPMs never get below 4350. Any thoughts on why this is? Should I consider more prop? Say, the Hammer? Or, maybe change the belt ratio?
BTW, I have a 21 inch transom and ordered the tall transom configuration of the HDR. Any way to verify that I have the right model?
Sat May 21, 2016 5:13 pm
Post Re: Performance problem - 18x48 w/ 37EFI
Tall transom should have 8 bolts in the clutch cover. What about your current prop? Is it worn bad? Could be part of your issue.
1854 Prodigy DPE Level 3 HDR
Sat May 21, 2016 7:17 pm
In my experience the hammer doesn't gain you speed. Is it a heavy boat? Open or full of boxes?
Sat May 21, 2016 7:24 pm
I am having the same problem, my boat has recorded 31 before, always did about 30. I noticed last year that I cannot get it past 26. Boat Dr is looking at it now. Could be prop, could be governor spring, could be valves, could be one of about 6 or 7 things probably.
VooDoo--what you get when you leave your Voo outside all night long.
Sun May 22, 2016 9:18 am
Thanks. I do have eight bolts in the clutch housing cover so I'm good there. And, the prop (as well as the entire rig) is new so that's not a factor. As for the boat, it is mostly open but the style of construction probably makes it a little heavier than a GatorTrax of similar size and shape -- but not that much. I did have two kids (125 & 50lbs), a dog, and a six gallon gas (in addition to the 10 gallon built-in tank) near mid-boat just to simulate a near hunting load.
I would figure that if the engine weren't running well, I wouldn't be able to keep 4300+ RPM. Is that right?
And I was thinking if slippage was the issue with the big blade, then maybe a hammer would grab more water. Sounds as if you don't agree. What is the benefit of the hammer blade then?
Any other thoughts come to mind?
Sun May 22, 2016 2:02 pm
Hammer will step a load quicker and just handle a big load better. If you're talking top end speed the big blade will be the one that provides the most out of the two. Im not sure a stock 37 can sufficiently spin a hammer either. Maybe try shifting the weight around in the boat, different boat/motor combos like different things. I doubt its your valves because it sounds like your RPM are good. Im also not sure should necessarily expect a steady 30 mph with a stock motor but you definitely have some speed left on the table.
Sun May 22, 2016 2:42 pm
i have an 1848 prodigy with a 35 gtr and can only hit 26.5. I have even decked the heads and gutted the exhaust.
1848 Prodigy with stage 1 35 GTR
BPS Pro Staff
Mon May 23, 2016 11:53 am
That sucks, im assuming its a loaded out boat?
Mon May 23, 2016 2:26 pm
1854 prodigy 4400 HDR runs 30 all day with 2 people
Mon May 23, 2016 7:10 pm
1754 prodigy- stage 2 GTR
Tue May 24, 2016 8:47 pm
Wed May 25, 2016 5:30 am
don't beleive most of the bullsheet on here. 25 is a good speed for a lawnmower engine on a big ass boat.
30 unloaded with the wind to your back in 18'' of water = 25 in deep water with regular load.
enjoy the boat, there will always be somebody with a faster boat, it is all some folks live for. lol
Wed May 25, 2016 6:07 am
I wouldn't call 1848 a big ass boat, but agree with what others are saying in regard to inflated speeds.
Wed May 25, 2016 6:15 am
The 1848 boats that I've built run about 27-30 with stock motors.
I built a 1852 loaded out and it hits about 27-28.
Don't think your speeds are horrible but the could be better.
Who built the hull?
Sent from my beeper
Wed May 25, 2016 7:06 am
Users browsing this forum: No registered users and 49 guests
