It is currently Thu Jul 03, 2025 12:02 pm
[ 4 posts ] |
What size prop? DIY -ish Surface Drive
rotten_1
Joined: Mon Aug 26, 2013 3:01 pm Posts: 21 Location: Wichita, KS
After trolling on this fourm and scouring the DIY sections i decided to build a surface drive with parts and pieces.
First I found a 27" Mud Buddy lower, picked up a Predator 670 motor new, and crashed McMaster & Car.
So... after fabricating a housing for the MB lower and started fabricating a transom mount, the last piece I need is a prop.
Specs are as followed:
Predator 670 Upper gear - 36 tooth 101.6mm Lower Gear - 45 tooth 124.46mm Gates 8m-1440-20 gt timing belt MB 27" lower
What prop would optimize the gears and motor combo.
Boat is a Xpress 1650 with foam still in it. (will be removed after this duck season)
Thanks for all the information.
_________________ Minimum wage jobs are for minimum experienced people.
Fri Oct 28, 2016 7:19 pm |
flint87
 Re: What size prop? DIY -ish Surface Drive
Man why would you admit to trolling us and then ask for help. Maaaaaaaan.
Fri Oct 28, 2016 8:47 pm |
rotten_1
crap, i'm out of the loop... NOT trolling: "make a deliberately offensive or provocative online posting with the aim of upsetting someone or eliciting an angry response from them."
I meant "cruising". or does that mean something else also?
Fri Oct 28, 2016 9:32 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
Not unless you like dudes too
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sun Oct 30, 2016 8:02 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 64 guests |
