It is currently Thu Jul 03, 2025 8:30 am
Reply to topic  [ 4 posts ]
 What size prop? DIY -ish Surface Drive
Post What size prop? DIY -ish Surface Drive
After trolling on this fourm and scouring the DIY sections i decided to build a surface drive with parts and pieces.
First I found a 27" Mud Buddy lower, picked up a Predator 670 motor new, and crashed McMaster & Car.
So... after fabricating a housing for the MB lower and started fabricating a transom mount, the last piece I need is a prop.
Specs are as followed:
Predator 670
Upper gear - 36 tooth 101.6mm
Lower Gear - 45 tooth 124.46mm
Gates 8m-1440-20 gt timing belt
MB 27" lower
What prop would optimize the gears and motor combo.
Boat is a Xpress 1650 with foam still in it. (will be removed after this duck season)
Thanks for all the information.
Minimum wage jobs are for minimum experienced people.
Fri Oct 28, 2016 7:19 pm
Post Re: What size prop? DIY -ish Surface Drive
Man why would you admit to trolling us and then ask for help. Maaaaaaaan.
Fri Oct 28, 2016 8:47 pm
crap, i'm out of the loop... NOT trolling: "make a deliberately offensive or provocative online posting with the aim of upsetting someone or eliciting an angry response from them."
I meant "cruising". or does that mean something else also?
Fri Oct 28, 2016 9:32 pm
Not unless you like dudes too :lol:
Sun Oct 30, 2016 8:02 pm
Users browsing this forum: No registered users and 59 guests
