Bpowell688
Joined: Sat Feb 05, 2011 3:09 am Posts: 37 Location: Texarkana TX
 GTR is pushing toward the driver hard?
What do I need to do? I've tried moving weight around and it's still doing it.. This is a brand new rig that I picked up yesterday. 17x54 35 gtr..
| Sat Jul 23, 2011 9:10 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: GTR is pushing toward the driver hard?
Sounds like tiller torque my boy, Does it do it when you trim down? Make sure your not trimming up to high. If that doen't fix it try bending the torque tab on the skeg a little to the left, right in front the prop. A pipe wrench or a couple desent size cresents will do the trick.
| Sat Jul 23, 2011 9:25 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Sat Jul 23, 2011 9:31 pm |
bayouboy
| Sat Jul 23, 2011 9:34 pm |
Chadb1010
Joined: Wed Jan 12, 2011 7:26 pm Posts: 221 Location: SETX
had the same problem with my GTR when i put my new shaft on.... this little device makes wonders and cured the problem.... http://www.basspro.com/Torque-Tab-Steer ... 72/-421321
_________________ SOLD Uncle J 4x4 edition with a Stage 1 GTRRRR
| Sat Jul 23, 2011 9:38 pm |
Bpowell688
Chadb1010
TRY THAT TOURQUE TAB B4 YOU GO BENDING CHIT ON UR BRAND NEW RIG..... I GOT MINE FROM MY LOCAL MARINE DEALER.... TEXAS FIX IT B4 A LOUISANA FIX BRO!
| Sat Jul 23, 2011 9:41 pm |
bayouboy
| Sat Jul 23, 2011 9:47 pm |
Chadb1010
mine didnt come with a bend like my stock shaft so i added that... tak'em gator did the same
| Sat Jul 23, 2011 9:54 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Are you blaze's bro? I had quite a bit of tiller torque with that mb i and moved the motor over 1-1.5" to the left and that did the trick for me.
Sent from my iPhone 5
_________________ 1850 & 36pd
| Tue Jul 26, 2011 4:45 am |
