1754 PD w/36 PD speed ? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=40518 |
Author: | tsbroscoe [ Tue May 07, 2013 10:27 pm ] |
Post subject: | 1754 PD w/36 PD speed ? |
What kind of speeds should I expect out of a 1754 36 hp '07 PD rig? Also what king of RPMs should I be running? |
Author: | SCmudder7071 [ Tue May 07, 2013 11:26 pm ] |
Post subject: | Re: 1754 PD w/36 PD speed ? |
CDMCHEVY is running the same rig except its a '12. He's running 29 solo. You should expect about the same if the prop is good and the valves aren't leaking which is likely. Set OOW rpm to 4300 and you should turn around 4000 if it's stock |
Author: | eljefe [ Wed May 08, 2013 5:35 am ] |
search feature or google search it....... |
Author: | tsbroscoe [ Wed May 08, 2013 7:30 am ] |
Author: | Quackhead62 [ Wed May 08, 2013 7:35 am ] |
get a valve job or just do a stage 1 mod an you would see a whole lot more bottom end and load carrying capaicty |
Author: | SCmudder7071 [ Wed May 08, 2013 8:02 am ] |
X2 on the stage 1 |
Author: | eljefe [ Wed May 08, 2013 8:04 am ] |
how many hours on the motor? |
Author: | tsbroscoe [ Wed May 08, 2013 8:33 am ] |
I have 84 hours on the motor... it is bone stock. Does anyone know the closet place to Northeast Texas that does reliable Stage 1 work? Also I am spinning around 3900 in the water right now... I havent ran the boat empty yet but with 3 people this past weekend I was running around 20 mph but seems to not have much hole shot... i am going to order new prop from PD but what would be the best size and pitch for top end speed? |
Author: | OwenDickeson [ Wed May 08, 2013 9:02 am ] |
Where at in NE Texas? |
Author: | cb5331 [ Wed May 08, 2013 9:52 am ] |
Author: | CDMCHEVY07 [ Wed May 08, 2013 9:59 am ] |
I had 3 people and a 35qt yeti full of beer a few weekends ago and was runnin a steady 24 bumping 25 in the rice fields. Stock 36pd on 1754 |
Author: | tsbroscoe [ Wed May 08, 2013 7:16 pm ] |
I live in Henderson bout 20 miles from Tyler |
Author: | cb5331 [ Wed May 08, 2013 7:22 pm ] |
Don't know anyone in that area, but Gary (deadbird8) may be able to help you out. He's over here in the dallas area. Or I think there is a guy in longview. Think his name is Mike. PM tylerduckman, I think he has the guy in Longview's info. |
Author: | tsbroscoe [ Thu May 09, 2013 3:44 pm ] |
Turned my RPMs to 4300 OOW and ordered a new prop I believe that will boost my MPH up pretty good... My current prop is at 11 1/2" so it was worn bad... Should I be expecting 27-29 mph now? |
Author: | Will [ Thu May 09, 2013 5:07 pm ] |
Author: | tsbroscoe [ Thu May 09, 2013 6:19 pm ] |
Author: | zibilich [ Fri May 10, 2013 4:58 am ] |
With a brand new Pro-Drive 36 with 7 hours i was avg about 26-27 with people 2 people in the boat, and about 29-31 solo on my 17/54,. |
Author: | Buddy [ Fri May 10, 2013 6:27 am ] |
I have a 2013 1754 with a 36 on it. With me, a 24 volt trolling motor and battery, a yeti cooler I run 27 mph. In shallow water with me, and a cooler in front I can hit 28-29. 30-31 stock is not really possible... |
Author: | CDMCHEVY07 [ Fri May 10, 2013 8:47 am ] |
I can honestly say I've bumped 30 for Half a second with an empty boat wind to my back and runnin with the current! Haha somethin bout that 30mph mark it just dont wanna run it |
Author: | Will [ Fri May 10, 2013 8:58 am ] |
Author: | CDMCHEVY07 [ Fri May 10, 2013 9:39 am ] |
It's the round one. Not a round chine but you know what I mean |
Author: | Will [ Fri May 10, 2013 10:11 am ] |
Author: | Buddy [ Fri May 10, 2013 10:20 am ] |
Author: | Will [ Fri May 10, 2013 10:26 am ] |
Author: | eljefe [ Fri May 10, 2013 10:30 am ] |
depends on how narrow the hull is. my 40" turns great because i can lean on it......in shallow water, nothing bites to turn. |
Author: | CDMCHEVY07 [ Fri May 10, 2013 11:37 am ] |
Author: | Will [ Fri May 10, 2013 11:40 am ] |
Author: | Buddy [ Fri May 10, 2013 11:42 am ] |
Author: | CDMCHEVY07 [ Fri May 10, 2013 1:04 pm ] |
Pretty fun if you ask me. Til it starts hoppin and you start spillin your beer |
Author: | Buddy [ Fri May 10, 2013 1:15 pm ] |
yea once it starts hoopin that ain't no good. I hate a lap full of beer.... |
