It is currently Fri Sep 05, 2025 9:59 pm
Reply to topic  [ 63 posts ]  Go to page 1, 2  Next
 Prodigy 1954 w/GTR 35 w/Heads, Cam, Exhaust, Ecotron EFI
Post Prodigy 1954 w/GTR 35 w/Heads, Cam, Exhaust, Ecotron EFI
MM Brand: Gatortail GTR
Horsepower: 35
Boat Brand: Prodigy
Boat Size: 1954
Boat Layout: V-Rake, Extended Deck, Fishtail Transom w/2 half boxes, cat walk trays, cat walks. See comments for all the options!
Speeds | Shallow Water: N/A so far
Speeds | Deep Water: 29.4-29.6 Steady
Total Boat Load With Gear Etc: Empty (without poling platform), 260lb driver, 10 gallons of fuel, spud poles, GPS, all the permanent options still in (cat walks w/ trays, half boxes, wet sounds, Seat bases, "Evolve" deck track system, reverse lights)
Conditions Tested In: Light breeze/chop
Speeds | Deep Water: 27.6-27.8 Steady
Total Boat Load With Gear Etc: Empty (without poling platform), 260lb driver, 10 gallons of fuel, spud poles, GPS, all the permanent options still in (cat walks w/ trays, half boxes, wet sounds, Seat bases, "Evolve" deck track system, reverse lights), Ulterra trolling motor and 2 batteries UP FRONT (made a big difference with that weight being up front, going to test with batteries in rear and probably end up moving them there)
Speeds | Deep Water: 24.7 Steady
Total Boat Load With Gear Etc: Empty (without poling platform), 260lb driver, 275 lb passenger, 180 lb passenger, 85 lb dog, 10 gallons of fuel, spud poles, GPS, all the permanent options still in (cat walks w/ trays, half boxes, wet sounds, Seat bases, "Evolve" deck track system, reverse lights), cooler with water and snacks, Safety gear and tools (spud pole winch, 4 life vest, anchor with chain and rope, socket set, hand tools), 2 dozen teal decoys, another 70 lb decoy bag (motion decoys (2 mojo teal, hidgon pulsator goose 20 some lbs, mojo feeder) and honker floaters), raffia grass netting which is probably 35 lbs dry.
Hammer prop @ about 3900 rpm
Both Speeds were achieved at around 4680-4700 RPM with Bid Blade prop
Will update with shallow water speeds as well as speeds with different loads (and if I move the batteries)
Comments:
EFI: Motor idles smoothly and consistently at 800 RPM, throttle response is great, and has plenty of power (as far as a 35 HP SD anyway) to get on step and push the boat. Haven't owned a carb version of this motor, but the EFI seems pretty good on fuel. I will say that the air filter system takes a little modification, I had it fall off just because the plastic is pretty rigid so it's hard to clamp on solid. I just ran a couple stainless screws (length carefully selected and done off motor so no plastic entered intake of course) under the hose clamp and it will never go anywhere. Less than $1 and 10 min, permanent fix.
Here are all the details on the build:
-Prodigy 1954 all 1/8", Prodigy Grass Camo
-GTR 35 with Hoyts head work, cam, Exhaust and EcoTrons EFI
-21" Sides
-Removable Grab bar
-Recessed Floor Bracing
-3 Seat Bases on Floor, 1 on Extended Deck
-Prodigy Fish Tail Deck/Transom w/2 half boxes and removable center deck section
-V-Rake w/ice breaker
-Extended Deck w/hatch
-Trolling Motor Bracket for Minn Kota Ulterra w/I Pilot Link
-Removable light bar with 12" Middle and 6" on each side, all Seelite WAV
-12 Gallon Permanent Tank w/gauge
-8 Foot Spud Pole Kit w/Holde
-Diamond Cut Turf on All Surfaces
-8" Cat Walks w/trays (1 bent, 1 vertical)
-Dual 1500 GPH Bilges w/JR Pump Station
-Shark Eyes
-Green LED Interior Lights
-Spud Pole Winch
-Humminbird 899 DI SI on RAM Mount
-Wet Sounds 10 Speaker Stealth
-12 Volt Plug and Dual USB Plug
-Rear Poling Platform w/Seat Base
-Prodigy Blind Kit (Not Pictured)
-Sliding Transducer Bracket
-"Evolve" Track system with 2 Moveable deck sections (see pictures for different setups)
-Bow Fishing Platform w/8 50 Watt Seelites Halo color on a bigfoot switch
-4 Welded-in Cupholders
I think that covers it, haha. Wanted a very modular and versatile boat, Prodigy delivered on my dream rig! Everything truly met or, most commonly, exceeded my expectations. The craftsmanship and fit and finish is second to none in my opinion.
In all fairness, I tried the best I could to nit-pick the boat and try and find anything that was "wrong" with it. I am a very particular person and am 100% happy with the boat. But, in writing an objective review, small as they are, these are the only "flaws" I found:
-Couple very small scratches in the paint where the turf was trimmed with a razor. Seriously cannot see them standing in the boat, noticed them vacuuming it out. I have scratched it far more it the week ive used it.
-The Starboard plug rubs the bottom of the boat just a little when tightening it. No big deal, but got a different style (factory had the little "t" screw) for $3, "problem" solved
These are seriously things that I don't know if many other people would notice, but I was so happy with the boat I tried to find any flaw just to be objective for this review. Even as particular as I am I am 100% happy with the rig, its as close to perfect as possible in my opinion. I do have quite a bit of money into it so trust me, if something wasn't right I would say it.
Thanks again Chad, Ashley, and the whole crew at Prodigy Boats, I couldn't be happier with the amazing quality product you all delivered for me!!!
Will post tons of pics under this post.
2015 Prodigy 1954 V-Rake w/GTR35 (heads, cam, exhaust, EFI)
Full Review of My Rig Here:
Sat May 30, 2015 9:00 pm
Post Re: Prodigy 1954 w/GTR 35 w/Heads, Cam, Exhaust, Ecotron EFI
Only letting me post 3 pics at a time but here it goes...
Sat May 30, 2015 9:08 pm
Movable deck Sections in place for bowfishing
Sat May 30, 2015 9:10 pm
Notice the Permanent Reverse Lights, they are sweet for dark launches or putting it the rig away at night as well.
Sat May 30, 2015 9:12 pm
GPS, Switch Panel, Light bar
Sat May 30, 2015 9:14 pm
Top Pic At Home in Michigan
Sat May 30, 2015 9:15 pm
Couple pics on how the moveable decks can be set up as a 3 man layout or a bench for use in a blind in addition to extending the front deck
Sat May 30, 2015 9:17 pm
Interior lights and proof that the bowfishing setup works awesome
Sat May 30, 2015 9:18 pm
Great looking rig!
Sun May 31, 2015 3:45 am
That is one awesome set up! I'm planning on building a winch setup like that to go in my spud holes. It appears you thought every detail out!
Every day I'm paddlin'
Sun May 31, 2015 7:36 am
Very nice
Can't wait to get mine
Sun May 31, 2015 7:39 am
Beautiful boat!
Mon Jun 01, 2015 8:27 am
that's an awesome boat man congrats!
Mon Jun 01, 2015 8:30 am
Thanks guys, like it more every time I take it out!
Mon Jun 01, 2015 9:29 am
Awesome!! My Prodigy is not as decked out as yours, but I am still loving it. Chad and his team make great boats.
Mon Jun 01, 2015 10:47 am
Boat porn !!
Mon Jun 01, 2015 10:54 am
That boat is sick.
Mon Jun 01, 2015 1:00 pm
Wow. Looks awesome
Mon Jun 01, 2015 9:01 pm
congrats on the rig. Looks awesome and puts up some great speeds for a big boat.
Mon Jun 01, 2015 9:12 pm
Sweet rig!
1852 Dfou custom 35gtr
Mon Jun 01, 2015 9:38 pm
Awesome looking boat! You'll love your Prodigy for sure...
1854 Prodigy/ Black Death 4500 w/ Ceramic Q Muffler/ Wet Sound 10 Speaker Sound Bar/ Rigid Light Bar/ Minn Kota Riptide/ Hydroturf/ LED Cabin Lights
Recent Argentina trip video I put together. Enjoy:
Tue Jun 02, 2015 6:36 am
Tue Jun 02, 2015 6:46 am
Thanks guys, definitely love the rig. Forgot to mention that the Ulterra trolling motor (auto stow/deploy, auto trim, etc.) with the I-pilot link is worth every penny. Not only is it cool as hell to just launch your boat, let it hold its spot, then drive it to the dock with a remote and jump on, its been VERY useful for fishing and bowfishing
Tue Jun 02, 2015 9:57 am
Congrats
1850 & 36pd
Tue Jun 02, 2015 10:12 am
Tue Jun 02, 2015 10:37 am
Awesome rig man! You've got to be happy with that!
http://www.gatorglide.com/
gatorheads@comcast.net
Tue Jun 02, 2015 6:40 pm
Tue Jun 02, 2015 8:05 pm
Good looking boat.
2015 GatorTrax 1750 /2015 GatorTail GTR35.
Wed Jun 03, 2015 7:53 am
There are some well thought out options on this rig. Congratulations. I may have to give them a call.
#willetcustom 2048, GTR 37EFI
Wed Jun 03, 2015 5:02 pm
Looks like a do it all rig man I can't wait to take delivery of mine
Wed Jun 03, 2015 8:45 pm
Awesome rig mike.. Those back up lights are badass!!
You can't fix stupid
Wed Jun 03, 2015 8:47 pm
Wed Jun 03, 2015 9:20 pm
Sweet boat!! I cant wait for mine to be finished! Where at in Michigan are you?
Thu Jun 04, 2015 8:08 pm
SE near ann arbor
Fri Jun 05, 2015 5:48 am
Amazing! Now all it needs is a little mud and duck blood on it. :mrgreen: Baptize it with good beer.
Mon Jun 08, 2015 5:50 am
I have personally owned five mud boats and as a former MM / boat dealer have sold many others. I thought I'd seen it all. Your boat is fantastic...nice craftsmanship and customization.
The back-up lights are a very cool idea. Well done. Enjoy.
Sun Jun 21, 2015 8:49 am
Very nice boat
Sun Jun 21, 2015 12:21 pm
I gotta say them moveable deck attachments are a sweet idea. Makes me want to sell this crusty ass jon boat of mine and upgrade.
Sun Jun 21, 2015 12:27 pm
I was looking at reverse lights the other day to add to the trailer wanted them in the boat also. How are yours wired??
Sun Jun 21, 2015 2:32 pm
Sun Jun 21, 2015 6:44 pm
