It is currently Mon Jul 14, 2025 11:08 pm
Reply to topic  [ 8 posts ]
 Gettin the prop off
Post Gettin the prop off
So I bought a used go devil LT 16 hp, And the prop is shot. measures 7 1/4. So I am tryin to get the m@#$%^ F#$%^& prop off and it wont budge. Put heat on it all I dare. Used penetrating oil, Big F#$%^& Hammer still nothing. Even made a 4 ft steel bar with a hole in it and still nuttin. Also welded 2 bolts to a 1 in socket and hit it with the impact and yet again nuttin. Any new ideas? Also can the fuel pump leak gas into the oil or would it most likely have been flooded?
Sun May 09, 2010 3:54 pm
Post Re: Gettin the prop off
hay buddy try the search tab at the top pf the page it will put on what others have done to get them off
Sun May 09, 2010 4:34 pm
Profile YIM
did that thanks. Pretty much covered all those options if I cut the prop thru the hub with a grinder will it crack in half? Of course leaving enough not to damage the threads.
Sun May 09, 2010 4:58 pm
Call Go-Devil and ask one of them.
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Mon May 10, 2010 12:03 am
It seams like you have done all the things you can to get the prop off, Don't drive yourself crazy! You'r going to spend the money for a new prop, order a new shaft from Go-Devil as well. I ran into the same problem a few years back and bought the shaft at Mr. Warren's suggestion. Don't remember the cost at the time, but it was UNDER $50.00! It only takes about 20 minutes to change the shaft.
"They call us civilized, cause we're easy to sneak up on!"
Mon May 10, 2010 4:01 am
Got it off. Hammer and chisel + drill. The nut never split it just gave up then spun off by hand.
Mon May 10, 2010 7:48 am
Fri Jul 02, 2010 11:35 am
I got it off by drilling the stainless nut from both sides til it let go.
Fri Jul 02, 2010 2:37 pm
Users browsing this forum: No registered users and 55 guests
