It is currently Thu Jul 17, 2025 9:38 am
Reply to topic  [ 7 posts ]
 prop question
Post prop question
I have a 20 hp Vanguard Longtail on a 1542 Alumacraft and a new Mudbuddy 9x5 prop. I am turning 3900 RPMS out of water and only 3100 when moving. Is this to big of a prop? Also this brand new prop has a bad vibration my old prop didnt have. I have a new shaft and all new bearings and seals and cant figure out this vibration thing from the new prop. Thanks
Sat Nov 06, 2010 6:23 pm
Post Re: prop question
well it shouldnt be to big of a prop, also you will lose som rpms because when your prop is in the water, it is having a harder time turning because of the water.as for the vibrations, i dont think it could be coming from the prop, but it can be a possibilty, is your shaft centered and everything?
Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Sat Nov 06, 2010 7:07 pm
Brand new shaft and it didnt vibrate with the old prop on the same shaft.
Sun Nov 07, 2010 7:02 am
if the prop is not balanced correctly ,then it can cause extermely bad vibrations.
Mon Nov 08, 2010 5:39 pm
You probably have the u joint bound up at the top. Shaft is probably in or out to far.
Tue Nov 09, 2010 7:27 pm
Tue Nov 09, 2010 7:41 pm
If it did not vibrate with the old prop, then as others have stated, the new prop is probably out of balance...
Tue Nov 09, 2010 7:43 pm
Users browsing this forum: No registered users and 64 guests
cron
