Thog13
 how to make your own longtail?
i need help in designig my futur homemade longtail!! please help!! and if you have made one will you please put up pictures!!
_________________ 1432 and needs a longtail!!
Wed Mar 02, 2011 9:46 pm |
aweyerman
Joined: Fri Sep 17, 2010 11:32 am Posts: 411 Location: Ohatchee, Alabama
 Re: how to make your own longtail?
I've got the plans for a weedeater mudmotor. I can email them to you if you want them. But it wouldn't really apply to a convention mudmotor...
_________________ 1648 Tracker 50 Merc Team Topwater-Alabama
Wed Mar 02, 2011 9:55 pm |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
go to duckhuntingchat.com and look at the boats and motors section. they got a thread goin like 7 pages long about homamde longtails. id put up a link but i just tried to get on theor forums and it wasnt working
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
Wed Mar 02, 2011 10:16 pm |
Thog13
yea i appricate it ill go look at that website
Thu Mar 03, 2011 4:24 pm |
Woodiebuster
Just come by and look at mine. motor pipe for drive tube 3/4 threaded shaft bearings seals flatbar ujoint prop Ill weld it all up pretty for ya
Thu Mar 03, 2011 8:16 pm |
fireman1293
Fri Mar 04, 2011 7:08 pm |
mnsherick
I've also been searching hi and low for some plans or detailed pics on a DIY long tail build. If anyone has some info on how to seal the shaft, and detailed pics of the frame I would appreciate it.
I also need info on how the 'clutch assembly' control works.
-Matt
Sun Mar 06, 2011 9:37 pm |
Woodiebuster
Sun Mar 06, 2011 10:00 pm |
fireman1293
Mon Mar 07, 2011 6:53 pm |
mudmarshall
i just made a longtail i used three bronze bushings, one on each end and one in the middle and have two greese zerks to fill the tube with greese, to seal it i have three seals on each end to keep greese in and water out, havent had a problem yet
Mon Mar 07, 2011 8:42 pm |
Thog13
why did you use three and just not two of them bushings
Wed Mar 09, 2011 3:48 pm |
fishon!!
middle bushing reduces shaft whip, helps it from bending.. etc.. yall need to look at the duckhuntingchat.com forum, dont have time to find the thread now, but there is lots of info about home built longtails on there. there is one guy that has a sticky thread, you can email him for longtail plans.
Wed Mar 09, 2011 5:26 pm |
