It is currently Tue Jul 15, 2025 6:03 pm
Reply to topic  [ 6 posts ]
 Seals and bushings
Post Seals and bushings
I got a 23gdlt and the mother pours out grease if I order new seals from go devil are they compatible with all year models and how much does that run?
Tue Jul 12, 2011 10:11 pm
Post Re: Seals and bushings
[youtube][/youtube]
no they change every couple of years. you give them your frame number and they will hook you up.
the early 2000 model seals are cheaper than the new style. just a few bucks apiece/ the new ones for the bottom are like $25.
Wed Jul 13, 2011 5:05 pm
Thanks
Fri Jul 15, 2011 10:14 am
Eat - Sleep - Hunt ! ! !
Fri Jul 15, 2011 11:09 am
Also make sure you shaft has no worn grooves in it or you'll be replacing them again shortly. Shafts aren't expensive to replace if you need too, depending on how long you ran it with bad seals will decifier you needing a new shaft.....trust me i've done this
Fri Jul 15, 2011 11:28 am
Fri Jul 15, 2011 11:45 am
Users browsing this forum: No registered users and 55 guests
