It is currently Wed Jul 16, 2025 4:11 am
Reply to topic  [ 9 posts ]
 gear reduction
Post gear reduction
Im looking into gettin a small LT 9hp -12hp range. I see that MB makes a couple gear reduction models. Im told that it enables u to run a larger prop,resulting in better performance out of a smaller MM. What do u guys think,, im trying to keep the weight down but i need to be able to push myself over a log or stump if i get high centered,,i dont care about speed at all. Im am outfittin a 14/36 weldbuilt crawdad .080. Seems to me you would loose in rpms at the prop but gain pitch with the larger prop,, would u just end up back were u started..any body runnin one
off the streets and on the creeks
15/42 crawdad 23 swomp
Wed Jul 20, 2011 9:42 pm
Post Re: gear reduction
I have the 12 gear red. on a war eagle 436 and it pushes fine. Had to go over a tree on its maiden voyage 2 adults and a 12 yr old. It would almost plane out put I needed to mess with the trim tab to get the motor up more.
Thu Jul 21, 2011 8:54 am
thanks,,,do you know what that thing wieghs,,,MB says 130
Thu Jul 21, 2011 6:29 pm
In the paper work it says 120, but who knows? As I bought it as a package for a great price, like half off.
Fri Jul 22, 2011 9:31 am
thats a little boat, ive got right about the same exacy thing u got with an 11hp i built. itll get highcentered and push over logs but im constantly ready for it to get ripped open. i assume u meant .080
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Fri Jul 22, 2011 8:51 pm
No, 120 is exactly what I meant!! He asked about weight not thickness.
Sat Jul 23, 2011 2:03 pm
-1436 flatbottom
Sun Jul 24, 2011 1:36 pm
:lol: my mistake.
Sun Jul 24, 2011 7:22 pm
actualy the bottom is a little over 3/4 in thick,,,lol,, my bad,,,,seems like if you go much past a 9hp you might as well go on to a 23,,,the weight is about the same
Sun Jul 24, 2011 9:15 pm
Users browsing this forum: No registered users and 62 guests
