It is currently Sun Jul 06, 2025 1:54 am
Reply to topic  [ 14 posts ]
 25hp kohler speeds?
Post 25hp kohler speeds?
have a 25hp kohler long tail on a 14foot semi v flat hull, took it out for the first time today and only topped out at 9mph. had 3 people and 2 dogs weighing in at around 660 pounds with everything we had. the boat was very stable and handled it well. it seemed very slow after reading some of the speeds others were running with smaller motors. the prop is a little rough on the edges but no dents or bends. could it be a worn prop or boat/motor combo just not ideal? I am new to mud motors and bought the set up used, just looking for advice. thanks
Sun Apr 28, 2013 8:03 pm
Post Re: 25hp kohler speeds?
Yes that is very slow. Could be a worn prop, measure it and see how long it is.
Sun Apr 28, 2013 8:27 pm
Probably worn prop. That load in that rig should prolly be around 15-18mph.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
1854 GTB Extreme 35GTR
Sun Apr 28, 2013 8:41 pm
from the center of the shaft to the widest part of prop right at about 4". I was running about 2900-3200 rpms at full throttle. what brand prop would you guys recommend? and what size and pitch would you recommend for running this setup?
Sun Apr 28, 2013 9:02 pm
What will it turn out of water?
Sun Apr 28, 2013 9:04 pm
Sun Apr 28, 2013 9:39 pm
Turn the gov up to around 44-4500 out of water, then take it back out and see how it does. If you need help figuring out where that is, you can download the owners and service manuals for free on kohler's website.
Sun Apr 28, 2013 10:41 pm
semi vee flat hull. If its a vee hull, that has a lot to do with bad performance. Post a picture of the hull.
You need a "flat" boat and a 16' flat would work 10x better than a 16' vee hull. A true flat displaces weight better and drafts shallower.
Mon Apr 29, 2013 6:17 am
So 3 people and 2 dogs at 660 pounds? Are the dogs shit zoooooo's? Add the weight of motor and battery ya got a boat that's ready to sink. 14' boat is too small for that load. CB is right on settin the governor. Make sure when ya open that throttle the governor arm is pulled as far as it will go.
Mon Apr 29, 2013 7:40 am
Thats WAY to much weight for that boat! Add gear,gas, battery(s) and decoys and your F'ed! I had a 25GDLT on my 16.6/48 and I could do 17, 14 with a full load and after the prop was super worn I once did 4mph with 3 guys and gear for 9 F'ing miles!! Burned all 6 gals of gas to!
Team Total ASalt
Mossy Oak Pro Staff
1854Gator Traxs w/HD pushed by a MB 5000.
Ams wrote:
If assholes could fly this place would be an airport
Wed May 01, 2013 9:41 am
Wed May 01, 2013 1:56 pm
How wide is the hill. That's a big load for 14 foot and the 25 kohler is not light.
Wed May 01, 2013 5:22 pm
Thu May 02, 2013 4:17 pm
i have a 16' x 42" semi v with a kohler 25 and with a full load i get 15mph so its probably your prop like everyone else said
16x48 alweld
35 gtr
Fri May 03, 2013 7:39 am
Users browsing this forum: No registered users and 59 guests
