It is currently Sat Jul 05, 2025 6:46 pm
Reply to topic  [ 13 posts ]
 v hull or flat bottom
Post v hull or flat bottom
Just curious i have a 20hp gdlt and im about to get a 14 foot v hull for free how will the lt do on a v hull its 14 foot by the way
17Foot Aquasport 85 Evinrude
20GDLT Looking for a Hull
Thu May 09, 2013 9:07 pm
Post Re: v hull or flat bottom
Short answer is not so good...but it will work. A better fit would be a 15-17' hull. It all depends as well where you run and the load you carry: that 14', if it a riveter, thinner gauge hull, may require beefing up the transom area. You will have to be very careful with balancing the weight, turning, make sure you carry all requisite safety gear; make sure the kill switch works and wear the lanyard! This is most definitely a limited 2 man at most hunting boat but for free a good deal. Let us know how it goes.
Fri May 10, 2013 3:20 am
Ya i know its a bit big for the hull but what im askin is would a flat nose jon be better than a flat trans v hull
Fri May 10, 2013 2:50 pm
To the best of my knowledge is a longtail works best on a long skinny boat. I was told that a longtail works better on a flat bottom boat better then a v Hull or semi v Hull due to the fact of how the water flow from under the boat. On a flat bottom boat the water will gather up and start the head of the wake just where the longtail cav. Plate and prop ride. On a V style Hull this head of the wake is farther behind the boat making it not a efficient and harder to operate.
now this is just what I've been told on mmt and unfortunately I can not verify this for you due to the fact I own a flat bottom. I ask the same question when I was looking for a rig. I was looking at a war eagle which is a semi V and was told by several people to stay away from a V so that's what I did.
hope this help and you might.try to use the search feature on this site for better information
Mon May 13, 2013 7:23 pm
You will definitely see better performance on a long, skinny boat for a longtail.
Mon May 13, 2013 7:33 pm
i have a 25 longtail on a semi v and the ride and performance isn to bad i can't compare it to a flat bottom tho cause ive never owned one
16x48 alweld
35 gtr
Tue May 14, 2013 2:23 pm
What Coupe said but I want to qualify what I posted- if you don't have a lot of mud, stumps, etc., you can get by with a semi-v like my tracker grizzly (not sure the angle of the bottom, partly vee mostly flat but has chines). I "cheated" a bit by adding steelflex (gatorglide is another product there are others) to help out over grass/mud areas by reducing friction. In those "hellilsh" marshes with all those impediments, a true flat skinny mud hull is the ticket for the LT.
Wed May 15, 2013 6:29 am
It is a 14 foot skinny hull round chines flat all the way to the bow its just at the bow it comes to a V im not sure what kind of hull that makes it but it is long and skinny with flat bottom just has a V front
Wed May 15, 2013 9:53 am
Just use common sense and it will work fine! Can't beat the price! :mrgreen:
Wed May 15, 2013 12:18 pm
X2^ but watch the semi v on the front on the boat because if you(sorry) when you hit a stump just under the water if its not dead center the boat will jump hard to the left or right so be sure to have a grab bar and WEAR your saftey kill switch and made sure it works. Because you may go swimming easier than with a flat bottom due to the angle on the bottom will catch the stump like a ramp. Good luck
Thu May 16, 2013 7:10 pm
Ya thanks a lot guys i figured it would work iv looked at some of the mud run photos and seen guys running v feonts just wanted to get yals opinion its greatly appreciated how much more balls you think the 20hp will have compared to the 13 i used to have
Thu May 16, 2013 9:15 pm
Night and day difference
Sat May 18, 2013 4:18 pm
Flat bottom!! The only way to go
Semper Fi
16x38 WC Skiff 35 MB HD
Sat May 18, 2013 6:34 pm
Users browsing this forum: No registered users and 62 guests
