It is currently Wed Jul 16, 2025 4:02 am
[ 6 posts ] |
hatchie rat
Joined: Tue Sep 22, 2009 2:29 pm Posts: 61 Location: west tn
 Cavitation plate help
im having trouble keeping it in the water at full speed. ive tried bending the tip up but it didnt help a whole lot, but my question is......is there anything wrong with just cutting the plate off completly or would it even be worth my time? if anyone has done this i would love to hear some tips
_________________ 1542 Landau w/ 20 hp BT Longtail custom dual exaust "Hatchie Bottom" paint job
Thu Nov 12, 2009 7:02 pm |
lparrish
 Re: Cavitation plate help
I had the same problem. I solved it by bending the leading edge of the plate down. I don't know what would happen if you cut the plate off. I think if it is set right it will help hold prop at the correct depth.
Thu Nov 12, 2009 8:47 pm |
cbrdux
short transom..bend cav plate up or straight tall transom...bend cav plate down you have to keep tweeking until you find the sweet spot where the motor wants to run. You should be able to run the motor with almost no effort.
Thu Nov 12, 2009 9:53 pm |
EasTexDux88
Joined: Tue Sep 29, 2009 3:08 pm Posts: 1069 Location: Longview Tx
yep, luckily mine was set up reeal nice when i bought it. never had a problem. it is bent up tho
_________________ ETD88 09/28/09-05/14/2010...
Fri Nov 13, 2009 1:13 pm |
hatchie rat
alright i bent the tip up a lil more, n im gonna go run it some tom so hopefully it will help. im a lil skeptical about cutting it off completly cause i don't want to warp the shaft from it getting so hot
Fri Nov 13, 2009 8:23 pm |
LaBirdman
Joined: Tue Jan 13, 2009 7:02 pm Posts: 274 Location: Galliano, LA
Prop wear will cause it to pop out like that. Measure your prop and see how bad it is to a new one.
_________________ Freedom It Wasn't Free!!! It Was Won!!! Enjoy It!!! The more you try to teach a stupid person something the dumber you get!!!
Fri Nov 13, 2009 10:25 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 55 guests |
