It is currently Sun Jun 29, 2025 12:26 pm
[ 7 posts ] |
Mike J
Joined: Fri Feb 21, 2014 7:12 pm Posts: 10 Location: Tallahassee, FL
 Go-devil problem
I have a 16hp go-devil longtail and lately it's been stalling after a few minutes of cruising. It runs fine out of water but when it's got a load on it it stalls. I run it multiple times per week and I run sea foam through it every 3-4 tanks. The carb was cleaned about six months ago. It also has new spark plugs in it. Any advice would be appreciated
Sat Mar 08, 2014 9:29 pm |
RootSumn
Joined: Thu Jan 13, 2011 11:55 am Posts: 1126 Location: Hawthorne, Fl
 Re: Go-devil problem
Had that happen on my old LT and it was a coil pack breaking down.
_________________ 1654 Grizzly '13 35 GDSD
"You should be more concerned with watching football than making chit fall out the sky!!!" - My Wife
Sat Mar 08, 2014 10:12 pm |
bigticket
Joined: Thu Jan 09, 2014 11:40 pm Posts: 94 Location: somewhere fishing
i just had my kill switch diode wire that runs between the coils go bad, dam thing was grounding out my coil even tho the diode was burned in two.
_________________ 1654 GDSD 37efi.
Wed Mar 12, 2014 8:37 pm |
kibb
We've got the same problem on a 16 at work
Wed Mar 12, 2014 8:58 pm |
BrownDog20886
Saw this a bit down the list and was curious about the outcome. Hope you got it figured out already.
Mine was doing a similar thing. It was a fuel starvation issue due to an overly restrictive fuel bulb (fancy one from BassPro). Once I replaced it with a regular Atwood fuel bulb from Walmart, my motor runs like a champ.
This is another possible cause if you've recently switched out some fuel line components.
Nate
Sat Mar 29, 2014 8:20 am |
Mike J
Nate, it turned out to be water in the gas tank. Got the tank and carburetor cleaned out and it runs great now
Sat Mar 29, 2014 8:58 am |
BrownDog20886
Glad to hear that.
Nate
Sat Mar 29, 2014 9:28 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 68 guests |
