It is currently Sat Jun 28, 2025 6:59 pm
Reply to topic  [ 13 posts ]
 Bent drive shaft need help!
Post Bent drive shaft need help!
Hey guys at full steam I clipped a rock or a log. Got her home and the prop is fine but bent the shaft. Is it worth straightening it or should I get a new one. Help please!
Sat Apr 19, 2014 11:18 am
Post Re: Bent drive shaft need help!
Get a new one.
Sat Apr 19, 2014 11:47 am
Where can you get one? It's a 35 hp marsh monster..
Sat Apr 19, 2014 12:04 pm
You take the old one out and go to your local machine shop and have them make a new one like it. They are prety straight forward.
Mark f. Cheney
on the Great Salt Lake marsh
Sat Apr 19, 2014 1:24 pm
Well the fun part is iv never disassembled a longtail.. can't figure out how the bearings come out and the prop is on there good...
Sat Apr 19, 2014 3:48 pm
And took me a 2 weeks to get a response from marsh monster the last time I called..
Sat Apr 19, 2014 4:31 pm
post some photos and Im sure we can help ya out, disassembly should be easy.... post pictures and the comments will come
1436 Lowe
Sat Apr 19, 2014 11:23 pm
Like said above
Get a new one.
Remove the prop, and the key from the top of the shaft- from the u joint yoke- pull from the bottom all the way out.
Wear gloves.
B. MacDonald
Sun Apr 20, 2014 6:50 am
To remove the prop - get a 2x4 or a piece of flat bar cut a 3/4" hole in it and leave it 3-4' long for leverage.
Put a wrench on the nut above the prop - use a tube or something for leverage on it - then pull towards each other and it'll release the prop.
B. MacDonald
Sun Apr 20, 2014 6:52 am
Ok here are some pics. The biggest issue I see to removing it thru the bottom is that the welded a washer onto the shaft. Sure I can grind it off but is there a reason for it? And to remove the shaft do I have to pull the bearing retainer out behind the prop? I did lightly tap the shaft down to which it feels like it is hitting something before the welded on washer hits the top bearing (that I can't get out). :evil:
Sun Apr 20, 2014 7:04 am
Sun Apr 20, 2014 5:58 pm
Cut it off, then pull it out.
If its bent you're going to get a new one anyways.
B. MacDonald
Mon Apr 21, 2014 6:16 am
1436 Lowe
Mon Apr 21, 2014 10:03 pm
Users browsing this forum: No registered users and 72 guests
