It is currently Tue Jul 15, 2025 10:39 am
Reply to topic  [ 15 posts ]
 throttle cable
Post throttle cable
has any one ever tired using a go devil surface drive throttle cable and squeeze thing on a long tail ?? and if not do u think it would work
BUNDY BUILT SKIFFLESS
cuz der bad ass like dat....
bunnny rabbit customs.
Thu Oct 22, 2009 6:59 pm
Post Re: throttle cable
dont know... would you have to put a spring on the carb so when you let off the gas it would slow down? It would be nice when you hit a deadhead or stump and kicks outta your hand. I went wide open into a d@mn tree like that. ben nice if the throttle was at idle as i was picking my butt up out the bottom of the boat...
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Thu Oct 22, 2009 7:06 pm
im thinking bout going buy one and seeing if it will work r not i think it would be alot easier to operate
Thu Oct 22, 2009 7:11 pm
maybe someone on here seen it done... If you do it, let me know how it works... Sounds like a good idea to me....
Uncle J 1848 w/?
Thu Oct 22, 2009 7:14 pm
oh i will ... i need to go to the go devil place and look at one first and see if they r the same ....
Thu Oct 22, 2009 8:12 pm
I have heard of people using bicyle brake levers as the throttle but ive never seen a picture of it. There are some guys on here though that have them.
1544 G3 with 23hp GDLT
Thu Oct 22, 2009 9:54 pm
i was thinking of doing the same thing to mine and was wondering how well it would work. let me know how it works for you.
37 EFI Prodrive pushing a 1748 Tim's Marine Custom Flat
Fri Oct 23, 2009 7:59 am
See this thread
viewtopic.php?f=6&t=1731
Fri Oct 23, 2009 7:20 pm
Yea I have done it....they aren't very expensive from GD. the throttle is a little small to slip right on there but it has a set screw that you can back out and take something like a dremel tool and make it bigger then tighten it down, which is what i did...and i like it alot...or you can go what i think would be a little more time consuming and cut the handle and find a piece that it'll fit on and weld it together.
Fri Oct 23, 2009 8:35 pm
thanks for the info hh really appreciate the help... :D
Fri Oct 23, 2009 10:44 pm
I made one out of a bike brake, it works pretty good, but I'm sure that a GD throttle would be a bit heavier duty.
Put yer face in the myrtles.
Sat Oct 24, 2009 8:21 am
lparrish: "My question is how should the throttle be set, to hold it's position or to return when released? The motor is a lot easier to operate when the throttle holds it position but it can get you in a bind if you need to reduce the motor speed and you can not get to the throttle quickly."
Anyone have any definitive answer on how it SHOULD be set? I too would like the throttle to return when released. I just took my 24 out for the first time after owning a Hyperdrive and the throttle issue was my number one concern. Would extra modification to the throttle/carb/spring have to be done? (Don't really want to get in to all that!) Thanks!!
Sun Oct 25, 2009 7:30 am
idk i have to drive a hour to go get one as soon as i get my laxy a$$ up and do it i let ya kno
Sun Oct 25, 2009 8:06 am
Naw I just hooked it up straight to where the other throttle cable went.
Mon Oct 26, 2009 8:14 am
Still haven't gotten around to doing this! Any more pics? I really don't want to cut my handle!! I ordered the billet style lever from MB but it was too small to go around the handle> How would you install a carb spring?
Mon Jan 18, 2010 8:31 am
Users browsing this forum: No registered users and 52 guests
