It is currently Fri Jun 27, 2025 10:17 pm
Reply to topic  [ 17 posts ]
 1018 Steel Rod
Post 1018 Steel Rod
Is this the right metal for the shaft?
http://www.ebay.com/itm/3-4-Diameter-x- ... TQ:US:1123
Tue Sep 02, 2014 10:45 am
Post Re: 1018 Steel Rod
To soft
Tue Sep 02, 2014 2:19 pm
I use either chrome clad 1142 hydrolic shafting or 17-4 stainless. The chrome cad is very smooth, polished, and moderately hard. It makes a good bearing surface and a good surface for the seals to ride on. The 17-4 stainless is quite hard, tough, and it wears well as a bearing surface too. It is a little more difficult to machine the threads in.
Mark F. Cheney
on the Great Salt Lake marsh
Tue Sep 02, 2014 4:05 pm
What's the best internet source to buy one?
Tue Sep 02, 2014 4:13 pm
What about 3/4 inch Dia. 1045 Cold Drawn TGP - Precision Shafting?
3/4 inch Dia. 304 Stainless Steel Round Bar ?
3/4 inch Dia. 1045 Cold Drawn TGP - Precision Shafting ?
3/4 inch Dia. 303 Stainless Steel TGP Precision Shafting?
Found at Metals Depot.
https://www.metalsdepot.com/products/co ... 20&aident=
Tue Sep 02, 2014 5:02 pm
I cant find 1142 steel on the web is this a typo?
Tue Sep 02, 2014 5:13 pm
Found Stainless 17-4 Annealed Cold Finish
Round PH
0.75"
Cut to: 84"
$56.77
UPS Ground $25.12
Tue Sep 02, 2014 5:25 pm
Tue Sep 02, 2014 6:20 pm
Tue Sep 02, 2014 6:51 pm
EDT-150 is a good material. Easily machinable.
Tue Sep 02, 2014 6:52 pm
Tue Sep 02, 2014 7:11 pm
Alloy Steel 4140 Annealed Cold Finish
Round
0.75"
Cut to: 84"
$27.27
Tue Sep 02, 2014 7:12 pm
Think I'll go with
0.75"
Cut to: 84"
$56.77
I'm using stainless elsewhere.
Tue Sep 02, 2014 7:17 pm
I have used 4140. It corrodes badly after 10 hours running time. The corrosion - rust - eats the seal surfaces which makes it impossible to hold lubricant.
303 and 304 stainless are commonly available but wear fast.
17 - 4 annealed is more difficult to find. It is much harder and tougher than 303 and 304 stainless. It takes longer to thread because it requires smaller cuts and lots more of them than free-re machining material. It is doable. It wears good as a bearing material in bushing designed systems - especially with liquid lubricants, as do the seal surfaces in the same. I pay $35.00 for 72".
Chrome clad hydrolic shafting has a VERY brightly polished and smooth surface. The chromed surface should wear good and not corrode either. The jury is still out on longevity for me. I have 17-4 shafts out there with several seasons and hundreds of hours on them that are still good.
Other various carbon bearing steel shafts readily corrode in my experience.
Mark F. Gheney
Tue Sep 02, 2014 8:48 pm
Mark F. Cheney
Tue Sep 02, 2014 8:49 pm
Wed Sep 03, 2014 5:51 am
Wed Sep 03, 2014 10:19 am
Users browsing this forum: No registered users and 54 guests
