It is currently Thu Jun 26, 2025 10:23 am
Reply to topic  [ 16 posts ]
 GD dieing
Post GD dieing
Got a new gdlt 16 couple month ago an been running fine. Took it out the other morning and it would run for about two minutes then choke down. Gas cap was off so couldn't have been that. Any ideas wat should check?
Fri Dec 12, 2014 4:30 pm
Post Re: GD dieing
Is the squeeze ball collapsing?
Fri Dec 12, 2014 5:04 pm
Post Re: GD dieing
Fuel cap,Fuel filter, fuel tank, check fuel line for leaks or kinks, old/bad gas, dirty carb, ask questions on MMT is the usual order when I have a problem, or drive with the choke on until I can't stand it any longer.
Good luck!
35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close
10hp Swomp lite 14-36 alumacraft
Fri Dec 12, 2014 6:07 pm
Post Re: GD dieing
:lol: ^^^^^^
Fri Dec 12, 2014 7:29 pm
Post Re: GD dieing
Sat Dec 13, 2014 10:02 am
Post Re: GD dieing
yeah the ball is collapsing LB200
Sun Dec 14, 2014 6:49 pm
Post Re: GD dieing
Sounds like the line or the pickup is clogged if the bulb collapses.
Sun Dec 14, 2014 6:55 pm
Post Re: GD dieing
ill check that out, preciate the help
Sun Dec 14, 2014 6:59 pm
Post Re: GD dieing
I saw a post on here about a year ago about some fuel lines that were shedding their liner like a snake skin and plugging up, just a thought if the bulb is collapsing .
Mon Dec 15, 2014 10:25 pm
Post Re: GD dieing
Tue Dec 16, 2014 5:30 am
Post Re: GD dieing
These guys are correct. If the ball is collapsing there is a restriction between the ball and the tank. Are there any other symptoms you haven't mentioned, like is the battery or the tool box setting on the fuel line? Why was the gas cap off?
Tue Dec 16, 2014 12:28 pm
Post Re: GD dieing
thought it needed to be off to vent but yall tell me, know hell of a lot more than I do
Tue Dec 16, 2014 4:51 pm
Post Re: GD dieing
Wed Dec 17, 2014 1:46 am
Post Re: GD dieing
had to of been it, little bastard was swimming around when I checked it
Wed Dec 17, 2014 5:32 pm
Post Re: GD dieing
Get now line at auto parts house and pump bulb from academy or wally world....
Use small diameter 3/8" line not larger 5/8" - it works better...
Then give it another try...
Eat - Sleep - Hunt ! ! !
Wed Dec 17, 2014 5:39 pm
Post Re: GD dieing
You should be able to blow back to tank from primer bulb end and it bubble up in tank. Primer bulb should be like a check valve - flow to motor not to tank. I have actually seen Mariner/Mercury fittings at tank not push ball in connector far enough to open/ btw mercury plugged into Yamaha fitting will cause that trouble also --- that is if you are using quick connect fittings. and also those attwood type quick connects are a big piece of shit! Personally I tend to stick with omc type fittings on tanks and hoses, have 3 boats and it makes it easier to move fuel and tanks where needed.
Thu Dec 18, 2014 8:45 am
Users browsing this forum: No registered users and 45 guests
