It is currently Mon Dec 22, 2025 12:29 pm
Reply to topic  [ 20 posts ]
 Losing Power
Post Losing Power
I am running a 35hp longtail. A few days ago I was coming out from a morning of duck hunting and the motor kept turning off every time the motor it would bog down and need more power. It would run fine out of the water but once you put the prop back in the water it would cut out. I have checked the calibrator and the coils and there does not seem to be an issue with any of them. Any other ideas of what could be causing this issue?
Thu Dec 04, 2014 9:16 am
Post Re: Losing Power
Not getting a enoungh gas u have you done any mods to it
Thu Dec 04, 2014 9:21 am
Vent the gas tank. Or air getting into fuel system. Those are easy checks.
Thu Dec 04, 2014 9:23 am
Could be running on one cylinder due to flashover (loosing spark from the boot to the metal air dam where the plug boot goes through the hole)
Thu Dec 04, 2014 9:47 am
Ya I had one only run on cylinder one time do to a bad spark plug easy way to check that is touch the header pipes if one side is hot and the other side is not you know it's only run on one cylinder
Thu Dec 04, 2014 10:24 am
Sound like something to do with the fuel
Thu Dec 04, 2014 10:30 am
Post Losing Power
I have had the same issue, bent push rod, ran fine as long as it didn't get in a bind
( which also means running on 1 cylinder but still was firing)
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Thu Dec 04, 2014 3:20 pm
Not mods have been done to motor. I have checked all fuel lines, carburetor, plugs, plug wires. While motor is running I pulled each side of plug wires and motor does not cut out so I do t think it could be a bad coil. One side of the header pipes is a lot warmer than the other side. If it does have a bad cylinder how can that be fixed. Keep in mind I am no mechanic. Is it something I can fix?
Fri Dec 05, 2014 4:13 pm
Say it idles good but when you put it in the water and give it gas it chokes dead
Fri Dec 05, 2014 5:00 pm
You got a tiny tach on it
Fri Dec 05, 2014 5:05 pm
It idles great. When prop is out of water you would never know anything was wrong even running wide open. When prop is in the water it is run with just a little gas but when you go to run it half throttle it cuts out.
Fri Dec 05, 2014 6:12 pm
How low you got it idle
Fri Dec 05, 2014 6:23 pm
I've had one do that to me before one time when I put a cold air intack on and one time had it idle to low
Fri Dec 05, 2014 6:28 pm
both times it was not getting enough gas
Fri Dec 05, 2014 6:32 pm
next time it starts to bog down pull the choke out a little, not all the way just a 1/4 pull. IF it clears up and gains rpm you have a slight clog in the high speed jet. Another issue it could be is the stator, motor will run fine until load is put on it.
Sat Dec 06, 2014 6:34 am
12 ft 11hp longtail
Merc 225hp TR20
Sat Dec 06, 2014 8:32 am
Rods have been checked and seem to be working good. Had a compression test done one cylinder tested 130 and the other was 110. Is that enough of a difference to be lossing power?
Sun Dec 14, 2014 6:14 pm
Have you check the valve lash yet
Tue Dec 16, 2014 11:37 am
The problem was in the carburetor. There was trash in the gas and jets were clogged.
Tue Dec 30, 2014 8:33 pm
Glad u got it fix bud put ya a good fuel filter on it and that keep it from getting trash in the carb
Tue Dec 30, 2014 10:18 pm
