It is currently Thu Jun 26, 2025 10:21 am
Reply to topic  [ 8 posts ]
 Improvements Longtail Plans?
Post Improvements Longtail Plans?
Was wondering if anyone knew of or could suggest improvements to longtail build plans?
I'm sure some of you have seen parts and design that could be improved.
Thanks
Tue May 05, 2015 12:57 pm
Post Re: Improvements Longtail Plans?
WHat plans do you have that you would like improved?
When I built mine I just looked at several models and picked the features I liked.
I also didnt have "plans" Just some ideas, some building blocks (motor and prop), and I got creative.
Wed May 06, 2015 7:27 pm
Wed May 06, 2015 10:04 pm
Like he said they're pretty simple, the one thing I would recommend is to use a bearing in a cage at the top of the shaft housing, this puts your only friction point that needs tp be greased below the surface of the water and if you get in a pinch you dont gotta worry about the housing having enough grease in it to cool a top bushing...
1436 Lowe
Thu May 07, 2015 4:34 am
Sun May 10, 2015 4:48 pm
lots. It is done several ways. look at the posted photos.\
Mark F. Cheney
on the Great Salt Lake marsh
Tue May 12, 2015 2:44 pm
Here is an example of what SwampDonkey is talking about, I think.
Thu May 14, 2015 11:33 am
Yep that's the basic idea, We use a bearing with a locking collar like pictured above however the bearing is bolted to the frame using a two retainer plates like pictured below...
1436 Lowe
Fri May 15, 2015 7:16 am
Users browsing this forum: No registered users and 44 guests
