It is currently Mon Jun 23, 2025 3:41 am
[ 4 posts ] |
Hernaja1
Joined: Tue Feb 19, 2013 11:29 am Posts: 2465 Location: Sulphur , La
 Transom angle ?
Just a quick question. Does transom height or angle matter on a boat for a long tail ? Was jw since me and a buddy were discussing it .
_________________ Dual 37 EFI GTR's pushing a 20/72 , CC, point bow , Old school drake Camo Willet custom.
Sun Dec 27, 2015 1:26 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: Transom angle ?
Yes it does but it's not nearly as critical as transom height/shaft length. The angle of the shaft into the water will determine the efficiency of forward thrust.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sun Dec 27, 2015 1:35 pm |
fireman1293
 Re: Transom angle ?
Shaft angle is the number one problem why guys are fighting their long tail to steer it. Look at it this way, the more vertical a cavitation plate is, the more downward thrust it will push the prop into the water. They are designed to ride close to the surface to allow maximum motor rpm and forward thrust. The deeper it dives the more you will have to push down on the handle to get the cavitation plate to the surface.
Sun Dec 27, 2015 1:52 pm |
Hernaja1
 Re: Transom angle ?
I should of ben more clear. Was jw will a GD hull with a long tail on it work with a GD surface drive as well ?
Sun Dec 27, 2015 1:58 pm |
[ 4 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 46 guests |
