It is currently Wed Dec 24, 2025 3:52 am
[ 9 posts ] |
Mpe_tx3
 Automatic lubricator
Wanted to see if anyone could give some insight into the automatic lubricator on a go devil. I can't figure if I'm supposed to just fill the lubricator compartment up or if I have to have a certain grease gun tip to get it actually inside the tail. I tried calling go devil and all the lady said was to not grease the lubricator seal (which I knew) then offered to send me a manual. Do you simply fill the entire thing with lubricant or do you need a needle styled grease tip to force it into the long tail? Thanks a ton
| Wed Nov 16, 2016 2:45 pm |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
The shaft should have a grease fitting about halfway down the shaft below the lubricator.
You pump the grease into here and any overflow pushes into the lubricator. As soon grease starts to overflow into the lubricator, stop. You're done.
Should only take 3-4 pumps usually. If it consistently takes 6-7, you probably need to replace seals and bushing.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Wed Nov 16, 2016 3:08 pm |
Mpe_tx3
 Re: Automatic lubricator
Is the fitting separate from the reservoir that is near the engine? When I bought it I was told to put the lubricant in the reservoir with the spring
| Wed Nov 16, 2016 3:16 pm |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
Don't put it directly into the lubricator. There is a separate fitting. The go devil manual is on there website and illustrates it.
| Wed Nov 16, 2016 3:48 pm |
cb5331
He doesn't want to look at the manual they offered to send him. He'd rather have someone explain to him what's in the manual, which has been done multiple times now. Just let him fill the lubricator like he wants to.
| Wed Nov 16, 2016 4:08 pm |
bbb
| Wed Nov 16, 2016 4:38 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
No no no.... Just fill that lubricator itself, don't worry about that silly grease fitting. I'm sure it's just there for looks anyway.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Wed Nov 16, 2016 6:29 pm |
dead animal
THEY SHOULD PUT A ZERK OR SOMETHING NEXT TO THE LBRICATOR THINGY TO FILL UP THE LUBRICATOR!!!
| Wed Nov 16, 2016 8:39 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Damn  Zerk on the shaft should fill the lubricator, if not then pump the zerk full and then push down on top of lubricator and twist slightly to remove the top.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Fri Nov 18, 2016 9:00 am |
[ 9 posts ] |
