It is currently Sun Jul 13, 2025 5:36 am
Reply to topic  [ 7 posts ]
 New to the mud motor world.. Need some help
Post New to the mud motor world.. Need some help
Got a few question.. I just got a longtail the guy I got it from said it's a godevil but I can't find any markings on it that says it is.. It has a Tecumseh HM100 on it.. r they good motors?? Also what should I look at far as replacing the guy I got it from didn't know much about it.. It has a 3 blade prop on it but iv also got a 2 blade witch would b best? It's o a 14' 36. What type of speed should I b getin out of this set up?
thanks for any help
Thu Sep 16, 2010 10:38 am
Post Re: New to the mud motor world.. Need some help
I dont know much about those motors.. If its a Godevil, it should have a serial number under the U-joint on the frame plate. I know on mine its REALLY dirty and takes a couple minutes with rags to even start seeing something etched in that plate. Do you have any pictures or it kicking around? If you get that number off the metal plate you can call godevil and they can tell you the year make and model of your motor. anywho. hope this helps. :)
Gee
Ps- welcome to the site. great place for info!
Fri Sep 17, 2010 1:38 am
I dont have a answer for you..
But, Welcome to the Site..
Love,
Uncle J
Fri Sep 17, 2010 6:47 am
Thanks I'll take a look.. What about the prop 2 or 3?
Fri Sep 17, 2010 1:40 pm
From what I understand godevil made 3 blade props but that was a long time ago. I would guess that 2 blade props are probably going to be your best bet. Check the width of the props and go with whichever one is larger. OR, just run it with the prop thats on it and if you dont like the performance your getting swap them out. its a 10hp motor right? is your 1436 rivited or welded? and how much weight will you be carrying? how is the bottom of the boat? any dents or hooks in the hull? Just a ball park idea of the speed you should be getting is probably between 10-12ish..?? give or take a little. I would suggest putting on a Tiny Tach if it doesnt already have one so you can see where your RPM's are sitting. Anywho. hope this helps. :) enjoy your new addiction.
Gee
Sat Sep 18, 2010 2:34 am
yes it is a 10hp motor and it is mod v rivited and the bottom is in good shape no dents.. itll just b carring me (210) and decoys 3-4doz... about the tiny tack do i want the prop that prduces the highest rpms or lower rpms??
Sat Sep 18, 2010 6:40 am
It just depends on which prop will get more bite in the water. if it spins to fast it probably means its to small of diameter and your not going to get very much speed. if it spins to slow it means you have to big of a prop. Plus the pitch of the props will throw in another variable. I'm afraid its just going to be a trial and error type of thing now..
Tue Sep 21, 2010 4:22 am
Users browsing this forum: No registered users and 54 guests
