cavitation plate question
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=14462
Author:  go-devil15 [ Fri Dec 10, 2010 7:47 pm ]
Post subject:  cavitation plate question
i have tried everything as to keep my prop in the water on my long-tail, and nothing has worked,so i guess ima have to bend my cavitation plate up. any tips on how to do this and some tools needed?
Author:  Woodiebuster [ Fri Dec 10, 2010 7:49 pm ]
Post subject:  Re: cavitation plate question
does it have a lil tab on the end of the cav. plate?
Author:  go-devil15 [ Fri Dec 10, 2010 7:54 pm ]
yep....
Author:  Orangefoot [ Fri Dec 10, 2010 7:55 pm ]
bend the end up and the back side angled edges down, solved my problem!
u may can jus hammer it up. i had to heat mine up because the frame was rebuilt by go devil and they used thicker metal the second time! heat would save time regaurdless.
Author:  go-devil15 [ Fri Dec 10, 2010 7:56 pm ]
thanks, will try that out tommrow.
Author:  Woodiebuster [ Fri Dec 10, 2010 7:59 pm ]
bend it up in small incriments till it does like you want it.
Use a bfw (big fking wrench)
Author:  go-devil15 [ Fri Dec 10, 2010 8:01 pm ]
thats your go-devil in the picture?
Author:  Woodiebuster [ Fri Dec 10, 2010 8:02 pm ]
yessir..
well, mud buddy actually
Author:  go-devil15 [ Fri Dec 10, 2010 8:03 pm ]
damn surely had to bend that plate up alot, what do u think causes the prop to come out the water even if you adjusted the trim bolt?
Author:  Woodiebuster [ Fri Dec 10, 2010 8:04 pm ]
the balanced frame and angle it goes into the water most likley.
Author:  go-devil15 [ Fri Dec 10, 2010 8:07 pm ]
so try to bend it up a lil at the time untill i hit the sweet spot?
Author:  Woodiebuster [ Fri Dec 10, 2010 8:10 pm ]
yeah, id say 1/8 at the time.
I actually let the motor come to the top and hold the motor where the cav. plate is an inch or so out the water in a surfacing mode to go a mph or so faster, it just gets tiring after a while.
Author:  marsh maniac [ Fri Dec 10, 2010 10:26 pm ]
a decent sized (12" or larger) cressent wrench would be preferred over a hammer. heat would help too.
Author:  mhgoodw [ Fri Dec 10, 2010 11:02 pm ]
go devil recommends using a crescent wrench, i'd say use a big one like marsh maniac suggested and if that doesn't work than try and put a pipe on the handle of the wrench to get some more torque
Author:  autogateman [ Fri Dec 10, 2010 11:24 pm ]
Author:  Mike W. [ Mon Dec 13, 2010 5:24 am ]
Worn out prop will make them blow out of the water too.
Mine has started to do this. Rather fight a bear with a switch then change the prop though! Guess I'll run it for the rest of the season and firht it this spring.
Author:  go-devil15 [ Mon Dec 13, 2010 3:44 pm ]
not the prop, its brand new
Author:  mississippiduckboy [ Mon Dec 13, 2010 5:09 pm ]
The screw would have very little to do with that unless, you have it set to high and its holding the motor out the water, and the mud buddy isnt that bent, just the way they build i bent mine to about a 45 at the tip and it works great.
Author:  brianb [ Mon Dec 20, 2010 9:36 pm ]
i originally had mine at a 45 degree, now have it at about 20 degree and it works fine
i tried straight, 45 and then 20 degree and the 20 degree spot worked the best but all are different, my brother in laws motor has to run flat, if you have heated it before, use a larger
cresent wrench and it will bend easily after the first time you heat it if it is 1/8 inch plate
