It is currently Wed Jul 16, 2025 11:26 pm
Reply to topic  [ 21 posts ]
 what kind of grease ?
Post what kind of grease ?
what kind of grease do ya'll suggest ?
Fri Dec 24, 2010 2:27 pm
Post Re: what kind of grease ?
Green Grease. Its 100% synthetic. Its also water proof and EP and disc brake wheel bearing rated. So you can use it in anything and everthing. Its great for boat trailer bearings too. Not cheap, but you get what you pay for!
Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Fri Dec 24, 2010 2:28 pm
thanks
Fri Dec 24, 2010 2:41 pm
another vote for Green Grease
MoMarsh Fatboy/2 Honda
Fri Dec 24, 2010 3:47 pm
Is that the name of it? Just asking because I bought some marine grease and its green in color
Bayou Gun Runner
Fri Dec 24, 2010 7:36 pm
thats the name
Sat Dec 25, 2010 1:12 am
Aqualube
Sat Dec 25, 2010 8:25 am
got it, thanks
Bayou Gun Runner
Sat Dec 25, 2010 8:31 am
99% will disagree but walmart marine lube works pretty darn good. when it comes to seals and bushing/bearings in a marine enviroment i was always told to look for a "weeping" grease. Walmart grease seems to keep my bushings and seals oily. It sucks in trailer bearings cause it weeps too much and slings the oily stuff everywhere. Its about 3.80 a tube and ive been using it since aqualube became hard to find around here. i use the blue drydene grease made by castrol in my trailer. I bought 2 cases of it when a local napa store went out of business.
Sat Dec 25, 2010 10:15 am
Sat Dec 25, 2010 12:49 pm
no you are misunderstanding the post. you dont look for leaking seals it the texture of the grease. it will have an oily discharge. btw bearings dont weep unless there sealed dumb ass. If you dont agree its fine to say so but dont disrespect me with a bs comment.
Sat Dec 25, 2010 1:53 pm
I run strictly ams-oil grease, works for me on the motor and trailer bearings.
Sat Dec 25, 2010 3:51 pm
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sat Dec 25, 2010 6:59 pm
I use Lucas Red n Tacky #2 grease. Its a high temp grease rated for marine use. I get it at Tractor Supply or Home Depot.
Sat Dec 25, 2010 7:07 pm
i believe everyone of you and i am all for running the good stuff. my seals are bad in my trailer thats why they leak. when i put walmart marine grease in the bearings they did leak worse. but i run it in my 1992 gtlt and i'm running the same bushings installed in 2001. i've ran walmart for several years and i really cant tell any difference in seal wear or any heat related issues. I dont put it in the hinge areas either just the shaft housing and i've had no issues. also check your local msds sheets in wal mart, super tech is produced by exxon mobile and is not as "cheap" a grease as most people believe. i work in the food service products and wal mart has higher specs on there brands than our name brand stuff. same as energizer batteries, they make the walmart batteries just a different label. I'm not sayin, I'm just sayin'! BTW wm grease is a lithium complex with a drop point of 500 degrees. Lucas Red n Tacky #2 grease has the same properrties and drop point.
Sat Dec 25, 2010 8:34 pm
I know grease plays a part in seal wear but conditions you are running plays a big factor also. I run one in a crawfish pond and had to hang the seals after three years eventhough it stays greased. This is due to the vegetation staying wrapped around the shaft and its eats at the wiper seal first then works its way to the othe two seals. Sand, dirt, and shell is what eats seals more than the quality of grease.
Sat Dec 25, 2010 10:24 pm
100% true my friend. i also think the fact that i run bushings vs. bearings might also make a difference.
Sat Dec 25, 2010 10:43 pm
what kind you use aint the impt.thing.....USING IT IS. ;)
Sun Dec 26, 2010 12:32 am
hey where you guys still finding aqualube? i see some new stuff on line called aqua shield "formerly aqualube" is that the same stuff?are you getting it from GD?
Sun Dec 26, 2010 6:42 am
18x54 WC custom
36PD EFI
Sun Dec 26, 2010 5:41 pm
Where are yall getting this quick silver anti corrosion spray? I cant find it.
Bayou Gun Runner
Sun Dec 26, 2010 6:36 pm
Users browsing this forum: No registered users and 55 guests
