It is currently Wed Jul 16, 2025 8:43 pm
Reply to topic  [ 7 posts ]
 transom problem
Post transom problem
i have a bass tracker hull with a 16 hp gdlt on it and the transom is at 21" would it be a good idea to cut it down to 16" or would that be 2 low?
Sun Jan 30, 2011 5:13 pm
Post Re: transom problem
that is what go-devil reconmends the transom height to be
Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Sun Jan 30, 2011 5:29 pm
would it be to low for that style hull with no flotation in the back? if so could i put pods comin off the back
Sun Jan 30, 2011 5:48 pm
how big is the boat?
Sun Jan 30, 2011 6:10 pm
1634
Sun Jan 30, 2011 6:13 pm
first off im pretty sure if you have a boat that skinny, it will get a little hairy at times......i know for sure your boat is long enough, as for width im not to sure...i would want to run a 16 on a boat that skinny, id go with atleast a 38 inch bottom....
Sun Jan 30, 2011 6:17 pm
i have a 1648 and cut the transom down to 16 with a 27 hp mblt. it sat low but i never had problems with back splash. you should be fine.
1648 w/ 27LT
Go Gators
Mon Jan 31, 2011 11:38 am
Users browsing this forum: No registered users and 62 guests
