go devil longtail losing mph https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=15743 |
Author: | tmgodevil [ Mon Jan 31, 2011 10:58 pm ] |
Post subject: | go devil longtail losing mph |
i was seeing if anyone can help me out with trying to figure out why my go devil is not as fast as it was right before duck season. It is a 20 hp go devil so its obviously not supposed to fly but 9 mph with only me and my lab...any answers? |
Author: | da go get'er [ Mon Jan 31, 2011 11:06 pm ] |
Post subject: | Re: go devil longtail losing mph |
check rpms and prop measurements. significant increase in rpms could mean prop wear. thats a good first step to diagnosing the issue. |
Author: | tmgodevil [ Mon Jan 31, 2011 11:17 pm ] |
i appreciate it bud ill be sure to do that first thing in the morning...ignorance haunts me but would you recommend getting a tachometer to be able to check the rpms |
Author: | GeeLeDouche [ Tue Feb 01, 2011 2:18 am ] |
Yup. get a TinyTach and it helps a ton! |
Author: | trev93 [ Tue Feb 01, 2011 8:56 am ] |
Sounds like your prop is gone! |
Author: | da go get'er [ Tue Feb 01, 2011 9:25 am ] |
I'd highly recommend a tach. not only does it serve as a diagnostic tool but also can give you engine hours which lets you practice a good mantience schedule. |
Author: | tmgodevil [ Tue Feb 01, 2011 10:34 am ] |
Thank yall for your help its much appreciated ... Where on the Internet is the bet place to buy a tinytach |
Author: | stualaska [ Tue Feb 01, 2011 3:46 pm ] |
As others have said, it sounds like a worn prop. Call Godevil with the serial number off the frame and order a prop and tach. Also, you can order a tach directly from the manufacturer at .... http://www.tinytach.com/tinytach/index.php |
Author: | tmgodevil [ Tue Feb 01, 2011 7:57 pm ] |
the tach has been ordered...any input on the best place to buy a go devil lt prop |
Author: | go-devil15 [ Tue Feb 01, 2011 9:06 pm ] |
buy it directly from go-devil themselves. if you go to their site, it will give you a little info on the amount the prop is gunna cost ya |
Author: | da go get'er [ Tue Feb 01, 2011 9:09 pm ] |
measure your prop before ordering. The diameter and pitch was originally a 9x4 most probably so see how small it is now. check your cup in the prop also. if you determine for sure you need a new prop call gd tell them your serial numbers off the motor they'll send you what you need. |
Author: | postalpaul [ Tue Feb 01, 2011 9:28 pm ] |
Has your motor been actin weird to start?Havin to choke it any more than normal?? |
Author: | tmgodevil [ Tue Feb 01, 2011 10:22 pm ] |
yeah man come to think about it some days it does act like that...any advice on whats going on |
Author: | mississippiduckboy [ Tue Feb 01, 2011 10:31 pm ] |
Clean your carb out, just cleaned mine out for the second time in 6 months, always getting clogged jets. |
Author: | tmgodevil [ Tue Feb 01, 2011 10:34 pm ] |
good deal bud ill be sure to do that thanks for the advise |
Author: | postalpaul [ Wed Feb 02, 2011 10:05 am ] |
Clean the fuel shutoff solenoid real good also |
Author: | bullsprig [ Wed Feb 02, 2011 12:51 pm ] |
If you've lost significant mph, it may be a combination of things already listed. Also maybe check the bottom of your hull. If you've been stump jumping all season you might have some dings in the rear of the hull that will slow you down aswell. goo luck. |
