It is currently Sun Jul 13, 2025 7:49 pm
[ 7 posts ] |
Orangefoot
Joined: Sun Jan 10, 2010 12:23 pm Posts: 519 Location: West Monroe, LA
 middle shaft bushing
how do you remove and replace the middle shaft bushing? seems quite difficult
_________________ Gatortail 1846 35hp GTR with calens stage 2 mods
Sat Jan 15, 2011 2:06 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
 Re: middle shaft bushing
I'm curious what the symptoms or problems are that caused you to want to remove the middle shaft bushing.
_________________ so many rivers, so little time
Sun Jan 16, 2011 6:35 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
removed drive shaft from end yoke. remove end cap. remove top bushing or bearing housing . take set screw out of middle bushing. pull driveshaft out past middle bushing and then use the shaft to push bushing out the top. does a middle bushing wear out? if it is, im guessing your drive shaft is bent.
Sun Jan 16, 2011 7:51 pm |
Orangefoot
im gona rebuild it from the yoke back! everything new! i dont wana leave out a part
Sun Jan 16, 2011 8:18 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
I've done a lot of work on lts , and have never heard of a middle bushing needing replacement. Jus my .02
Sun Jan 16, 2011 8:22 pm |
Mike W.
Joined: Thu Jan 15, 2009 2:26 pm Posts: 146 Location: Vanceboro, NC
Coco built them for a long time WITHOUT a middle shaft bushing. All it does is keep the shaft from whipping when you get in the heavy stuff.
I remeber the shaft on my 20 LT having a grove in the area of the grease fitting for a LONG time. Mr. Warren told me that was from the shaft whipping and not tom worry about it.
Had the new bearning setup installed in 04' and they installed the center bushing at that time. Go-Devil said that that was just to stop the shaft whip. I ran the motor for 4 years before with no problem.
Just my $.02
_________________ "They call us civilized, cause we're easy to sneak up on!"
Mon Jan 17, 2011 5:44 pm |
fireman1293
Sat Feb 19, 2011 9:44 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 45 guests |
