It is currently Fri Jul 11, 2025 7:22 pm
Reply to topic  [ 9 posts ]
 lt wants to dive deep when running at all speeds
Post lt wants to dive deep when running at all speeds
is it normal for a long tail to dive in the water or shold it sorta flot when running. I never had one befor i just ran it today for the first time and want some advice on to run on. Any advice wood be sooo grate
Sun Apr 10, 2011 11:26 am
Post Re: lt wants to dive deep when running at all speeds
The cav. Plate should hold steady at an inch or two below the water.
Sun Apr 10, 2011 12:07 pm
ive ran my new on the past two weekend and in deep water it wanting to go down deep when not a high rpms but when you get to WOT it jumps up to the top of the water. every now and then it wants to pop out the water at WOT, that means i need to bend the cav plate down a lil bit right?
Don't Tread on Me
Sun Apr 10, 2011 8:00 pm
adjust the trim tab on the cavitation plate until you find the sweet spot for your particular setup, we had one that we ran with the trim tab almost level to make it run right, on another we had to bend it down slightly to about a 30 degree angle or so, you also may need to adjust your bolt that is under the pivot plate so it does not go quite as deep in the water
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sun Apr 10, 2011 8:04 pm
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Apr 10, 2011 8:13 pm
ight thanks kibb and i just put a crescent wrench on the plate and bend it a lil bit?
Don't Tread on Me
Sun Apr 10, 2011 8:33 pm
mine does the exact same thing. dives deep then jumps out of the water at wide open. guess i'll have to tweak it too
Tue Apr 12, 2011 9:40 am
Tue Apr 12, 2011 6:38 pm
That's right. That bolt only should be stopping it from going too far down when you're stopped.
sent using tapatalk while smoking a cigarette, messing with the radio, and texting while driving all at once.
Tue Apr 12, 2011 7:02 pm
Users browsing this forum: No registered users and 58 guests
