It is currently Sun Jul 13, 2025 1:04 pm
Reply to topic  [ 35 posts ]
 LongTail or ShortTail build ????
Post LongTail or ShortTail build ????
Hey guy's i'm new here like a lot MMT !!!!
I was looking at all the topics regarding building my own MudMotor and by reading all the topics I am more motivated to do one. Because where I hunt water levels can change very fast so one week-end I can go in with my 25hp mercury and the week- end after you have to get the motor up and go with the minnkota...... so I am thinking of upgrading and i would like to build one because I live in Quebec, Canada and these motors are expensive like hell !!!!!! So I am thinking about building a shortTail but after reading it looks easier to build a longTail. I have a 1436 Jon Boat and I am aiming for speed. Can someone help me please ???? :D
I checked the plans sold on ebay and maybe if I decide by doing a long tail I will buy them but I would really like to build a short tail....
ramz007
ramz007
Wed Apr 13, 2011 2:20 pm
Post Re: LongTail or ShortTail build ????
If ya aiming for speed stay with the outboard,
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Wed Apr 13, 2011 5:34 pm
hes meaning compared to a longtail, unless you buy a 31 like b coonass lol
Wed Apr 13, 2011 5:42 pm
your hardest thing to do on a surface drive will be the transom brackets.
A mm is a ton heavier than an outboard too.
I have a 2 stroke 25 and a 13 longtail and I can barley handle the lt by myself.
Wed Apr 13, 2011 7:10 pm
Garrettpearce you're bullseye I am comparing it to the speed of the short tail vs the longTail......
what do you think guy's I should go with ??? number of Hp ....
ramz007
Wed Apr 13, 2011 7:49 pm
Hey Woodiebuster the transom bracket I have ot figured out what is fooling me now is the shaft.... I know its almost the same for the both except the long has a U-joint and the shorttail is a Strap or Chain to make it turn the prop I can fix something but my main concern now is the shaft with all the bearings etc......
For the handle I am not worried after a few times on the water I am sure I'll be good. ;)
ramz007
Wed Apr 13, 2011 7:54 pm
i have thought about it a thousand times and i have everything on paper except the shaft. if you have access to a machine shop it would be fairly easy
Wed Apr 13, 2011 7:59 pm
Yesss I have access to a machine shop :) but I saw a motor that was done all in aluminium .... Do you think it would be better ??? but if it is metal my uncle has a machine shop so I would be fine but I think we have the same issue lol the shaft.....
I thought of putting the pulley on the shaft smaller than the one on the motor bigger so I could get more rotation on the prop. do you think that will matter with anything ??
ramz007
Wed Apr 13, 2011 8:05 pm
go all aluminum heres a website that will hava alot of what your looking for...............mcmaster.com
Wed Apr 13, 2011 8:12 pm
you better have a 350 up top, that thing will have NO bottom end.
here are the aluminium short tail motor pictures:
http://i204.photobucket.com/albums/bb22 ... 011016.jpg
ramz007
Wed Apr 13, 2011 8:13 pm
If you go the sd route, will the frame be weighted back or balanced?
Wed Apr 13, 2011 8:16 pm
if you put the small pulley on the bottom you would have to put a small diameter prop on it and it wouldnt be a surface drive
Wed Apr 13, 2011 8:17 pm
if your building a small one build it where it would be weighted to the prop as if the engine were hanging off the back of the boat
Wed Apr 13, 2011 8:18 pm
also hf has 13hp for under $400 and theres tons of mods for them at affordablegokarts.com
Wed Apr 13, 2011 8:20 pm
hey mcmaster.com is an awesome site and i can find everything but i don't think they ship to canada.....
ramz007
Wed Apr 13, 2011 8:24 pm
What do you mean woodie by the sd route ???
ramz007
surface drive
Wed Apr 13, 2011 8:25 pm
What do you think will be best I was thinking about going weighted back but do you think balanced will be better ?
ramz007
Wed Apr 13, 2011 8:31 pm
thanks garrett ... :)
ramz007
Wed Apr 13, 2011 8:32 pm
Either way you'll have to find out how to keep your prop at a desired level.
Wed Apr 13, 2011 8:35 pm
i would go weighted back so that the prop will stay in the water easier while running
Wed Apr 13, 2011 8:37 pm
Ok.
I am thinking now about the shaft....
Do you think I shoul put bushings or bearing in the shaft between the inside one end the outside one ???
I was thinking bearings but saw that some putted bushings.
ramz007
Wed Apr 13, 2011 8:45 pm
yeah but its not gunna stay at the surface more than likley, especially when he lets off the motor... hes gunna have to have some kinda trim.
I was thinking about something like that Woodie look how this guy made his transom mount:
[youtube]http://www.youtube.com/watch?v=xxvkzZmdxr0[/youtube]
ramz007
Wed Apr 13, 2011 8:58 pm
itd do okay, but you cant fine tune much and would be a bitch to reset every time you hit somethin.
Wed Apr 13, 2011 9:01 pm
yeah thats it but i am thinking of doing a way so when the motor hits something its bouces up like and outboard... More work but i think its worth it ......
ramz007
Wed Apr 13, 2011 9:06 pm
how big you think the inside shaft should be ????
ramz007
Thu Apr 14, 2011 5:56 pm
Figure out what prop your usin first.
Thu Apr 14, 2011 6:52 pm
for that i have to know what hp I'll be running
ramz007
Thu Apr 14, 2011 11:39 pm
have you ever seen a copperhead?
Fri Apr 15, 2011 5:56 am
what do you mean by copperhead ?
ramz007
Fri Apr 15, 2011 8:09 am
search.php?keywords=copperhead&terms=all&author=&fid%5B%5D=5&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Fri Apr 15, 2011 3:17 pm
ah Ok the mud motor. Ya I heard about it. But here where I live we only have mudbuddy's and go-devil. trying to find one use but No ONE has any !! So that is why I am going to build one ;)
ramz007
Fri Apr 15, 2011 3:57 pm
hey woodie look a this guy :
ramz007
Fri Apr 15, 2011 3:58 pm
Users browsing this forum: No registered users and 44 guests
