It is currently Mon Jul 14, 2025 6:48 pm
[ 4 posts ] |
Bigwaterducker
 GO Devil Season Prep
Have a GD long tail. What do I need to check or do to make sure it is ready for the season? I keep it lubed and it doesn't seem to use a lot of oil or grease and the shaft housing seems to stay realtively cool. I see a little seepage around the prop but ovrerall not much. The motor I change all the oil, filters, plugs, and starter rope each season.
Sun Jun 12, 2011 5:48 pm |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
 Re: GO Devil Season Prep
make sure the shaft and u-joints dont have any play, the shaft may have a little little tiny bit, thats normal. if its holding grease then its pretty much good to go. maybe gap your plugs, change fuel filter, check the wear on your prop... not much to it.
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
Tue Jun 14, 2011 7:01 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
Here is what I used to do. Pull the rope or turn the key, If it would crank up, Id run the piss out of it. Thats about it.
But seriously, sounds like you are in good shape. As long as its not losing much grease youre good. Make sure the u joint doesnt have much slack and keep it greased up good.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Tue Jun 14, 2011 7:07 pm |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
Change oil and filter every spring, check the plugs Run some seafoam every now and then Every other outing check/grease it
Tue Jun 14, 2011 8:51 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 47 guests |
