It is currently Sat Jul 12, 2025 10:50 pm
Reply to topic  [ 14 posts ]
 New to mud motors.
Post New to mud motors.
Hey yall,
I just bought two older go-devil long tails and I had some questions. One is 8hp and the other is 6. The 8 runs, but needs some work. I’ll start first by cleanin out the carb and see how she does. The engine on the 6 is seized. I paid 300 for both. Was this a good deal or did I get took for a ride?
I want a smaller, more portable mud motor, so I’m in the process of rebuilding the 6. I took the prop nut off, but the prop wont come off. Is there something else I need to do to get the prop off? Will a puller work?
I’ve been wantin a mud motor for a long time, but was never in a position to get one, until now. I’d like to get the 8 runnin better, sell it and hopefully make enough cash off that to buy a small boat to put the 6 on. I thought about a gheenoe, if I can find one. Does anybody on the forum use one with a mud motor? Any advice for somebody new to mud motors would be appreciated. Thank you kindly.
Tue Jun 07, 2011 5:12 pm
Post Re: New to mud motors.
I have the 8hp. to, it leaks gas from the carb bowl, and i dont know what to do to stop this but other then that it runs like a mother phucker. Good luck wit the prop, i have been working for two days and still cant get mine off.
Team Arc Angel Bowfishing
Tue Jun 07, 2011 5:28 pm
sell the 6 keep the 8, the weight diff. isn't nearly big enough to loose 2hp over.
Tue Jun 07, 2011 5:41 pm
thats a very good deal. if ya wanna sell the 6 let me know please. id like to look at it, if youre not too far.
-1436 flatbottom
Tue Jun 07, 2011 5:46 pm
i believe those props thread on. so a puller would do no good i had a older 5 hp and i took a long drift punch and stuck it thru the u-joint and engine mounting frame and used a hard plastic dead blow hammer to tap it loose. good luck
Tue Jun 07, 2011 6:39 pm
missi boy have u tried a new bowl gasket set. or maybe the bowl is bad if thats where it is leaking
Tue Jun 07, 2011 6:41 pm
Its coming out the bolt hole that holds the air filter on, and it leaks out the other part where the rod come up from the air filter.
Tue Jun 07, 2011 7:42 pm
ive got a harbor freight motor that leaked somewhere out of the carb, not sure if it was the bolt or if it was a combination of the bolt and from somewhere else leakin down and drippin off the bolt. but it was just from not shuttin off the fuel valve when not in use.
-1436 flatbottom
Tue Jun 07, 2011 8:21 pm
Wed Jun 08, 2011 12:06 pm
MMT Site Admin
Welcome to the site!
Tony Broussard
Admin | Owner
Admin | Owner
Admin | Owner
Admin | Owner
Admin | Owner
CEO | Graphic Details Digital Media
Wed Jun 08, 2011 12:19 pm
missi boy have u tried a new needle and seat and than. reset ur float level
Wed Jun 08, 2011 7:07 pm
If I was putting a motor on a Gheenoe I would use the 6 hp. The difference in weight between a 6 and 8 is about 30 lbs. I wouldn't want to add that much extra weight on the transom for 2 hp.
Wed Jun 08, 2011 7:14 pm
Wed Jun 08, 2011 8:24 pm
Thanks for all the advice and for the warm welcome! :D
Fri Jun 10, 2011 9:31 am
Users browsing this forum: No registered users and 38 guests
