It is currently Sun Jul 13, 2025 6:27 pm
Reply to topic  [ 7 posts ]
 disasembly on a mud buddy
Post disasembly on a mud buddy
started taking the mud buddy apart today to replace the bearings and i am just trying to make sure there is no special order to get the shaft out and then once the shaft is out do the bearing housings just thread off the shaft housing or are they permantently attached to the housing and how are you supposed to get the damn prop off im guessing that it threads on to the shaft ??? never done this before and just dont wanna add more trouble and problems to my original problems of just replacing bearings any help is appreciated
17Foot Aquasport 85 Evinrude
20GDLT Looking for a Hull
Mon Jun 06, 2011 4:28 am
Post Re: disasembly on a mud buddy
alright well i got the prop off and im trying to slide the shaft out i had to pull out the bottom zerk fitting and now i am getting stuck on something i cant tell if its getting stuck on the bearing housing or not but the question i have is is there a certain trick to slide the shaft out or do you have to take off the top bearing housing and how do you replace the bearinghs im guessing you have to take the housings off but i tried with a pipe wrench and the housing isnt moving any help would be greatly apprecited
Mon Jun 06, 2011 3:57 pm
this is alongtail right? i dunno how exactly nudbuddys are put together but it should be very straightfirward. shouldnt even have to take the prop off to remove shaft. on most longtails its just a set screw at the u-joint holding the shaft in. remove that set screw and it should come out. as far as the bearing houses it may be threaded on or possibly welded.. for that i dont know what mudbuddy does.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Mon Jun 06, 2011 4:52 pm
i took the prop off because i thuoght you needed too i unscrewed the set screw holding the retaining collar on the forward bearing the one on top and then i can get the shaft to slide but i cant get it to come out all i need to do is replace the bearings
Mon Jun 06, 2011 5:11 pm
On a go devil long tail the bearing assembly on top and the seals on bottom are threaded on to the shaft tube. You might need a slide hammer that you can thread on where the prop goes. Pop it a couple times and the shaft should come right out. If its hanging up on the bottom seal, unscrew it and let it come off with the shaft. worry about getting it off the shaft once its out of the shaft tube. Make sure the key is not in the shaft keyway before pulling it through.
Mon Jun 06, 2011 6:06 pm
well i got she bottom cap out of the housing but its like a bearing it the bottom insyead of a seal and i am not sure how to get the lower and uppers bearings out the shaft is pretty much free i know i need a piece of tube to pull the shaft out of the upper seal but even once the shafts out i still am not sure how to get the bearings out i dont know just getting frustrated
Mon Jun 06, 2011 8:48 pm
Best bet is to go to mud buddy's web sight and go to the forum and ask the experts. I've never replaced the shaft, but they will help.
http://www.mudbuddy.com/forum/forum.php
MB 35hp LT/1754 Grizzly
Tue Jun 07, 2011 10:21 am
Users browsing this forum: No registered users and 55 guests
