GO Devil Season Prep https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=19214 |
Author: | Bigwaterducker [ Sun Jun 12, 2011 5:48 pm ] |
Post subject: | GO Devil Season Prep |
Have a GD long tail. What do I need to check or do to make sure it is ready for the season? I keep it lubed and it doesn't seem to use a lot of oil or grease and the shaft housing seems to stay realtively cool. I see a little seepage around the prop but ovrerall not much. The motor I change all the oil, filters, plugs, and starter rope each season. |
Author: | fishon!! [ Tue Jun 14, 2011 7:01 pm ] |
Post subject: | Re: GO Devil Season Prep |
make sure the shaft and u-joints dont have any play, the shaft may have a little little tiny bit, thats normal. if its holding grease then its pretty much good to go. maybe gap your plugs, change fuel filter, check the wear on your prop... not much to it. |
Author: | Tenpoint [ Tue Jun 14, 2011 7:07 pm ] |
Here is what I used to do. Pull the rope or turn the key, If it would crank up, Id run the piss out of it. Thats about it. But seriously, sounds like you are in good shape. As long as its not losing much grease youre good. Make sure the u joint doesnt have much slack and keep it greased up good. |
Author: | postalpaul [ Tue Jun 14, 2011 8:51 pm ] |
Change oil and filter every spring, check the plugs Run some seafoam every now and then Every other outing check/grease it |
