It is currently Mon Jul 14, 2025 11:47 pm
[ 2 posts ] |
Transom Mounting Brackets? HELP!
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
Alright, I just about got all the parts i need for my build, however... The one part that gets me is the bracket that is used to mount the frame of the longtail to the boats transom. What i meant is that I know how I want to set up how it pivots and everything its just that I dont know what to do for this portion of the longtail. I have a longtail frame that we are basically copying but in that guys build he salvaged a mounting bracket from and old outboard and rigged it up with some flat bar to accept a bolt. I was wondering it would be fairly easy to build one? or is there a place i could possibly buy one?
Thanks!
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
Fri Jun 17, 2011 7:37 pm |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
 Re: Transom Mounting Brackets? HELP!
its just 3 plated welded together to fir over the transom, flat bar laid perpendicular on iot to reinforce it. drill holes in the plate and weld 3/4'' nuts on the outside and put bolts on those. i welded washer on the ends of my bolts to give it more surface area. not muc to it at all.
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
Fri Jun 17, 2011 10:29 pm |
[ 2 posts ] |
Users browsing this forum: Google [Bot] and 44 guests |
