It is currently Mon Jul 14, 2025 12:48 am
Reply to topic  [ 2 posts ]
 Transom Mounting Brackets? HELP!
Post Transom Mounting Brackets? HELP!
Alright, I just about got all the parts i need for my build, however... The one part that gets me is the bracket that is used to mount the frame of the longtail to the boats transom. What i meant is that I know how I want to set up how it pivots and everything its just that I dont know what to do for this portion of the longtail. I have a longtail frame that we are basically copying but in that guys build he salvaged a mounting bracket from and old outboard and rigged it up with some flat bar to accept a bolt. I was wondering it would be fairly easy to build one? or is there a place i could possibly buy one?
Thanks!
1436 Lowe
Fri Jun 17, 2011 7:37 pm
Post Re: Transom Mounting Brackets? HELP!
its just 3 plated welded together to fir over the transom, flat bar laid perpendicular on iot to reinforce it. drill holes in the plate and weld 3/4'' nuts on the outside and put bolts on those. i welded washer on the ends of my bolts to give it more surface area. not muc to it at all.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Fri Jun 17, 2011 10:29 pm
Users browsing this forum: No registered users and 48 guests
