16 HP home build question https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=19515 |
Author: | montrose trapper [ Fri Jun 24, 2011 7:20 pm ] |
Post subject: | 16 HP home build question |
Hey guys I planned on making a 6.5 hp home build but ran across a 16 hp horizontal shaft for 150 bucks so i snapped it up. Now im having second thoughts. I over looked the fact that it was a IC and not a v-twin. My question is does it matter? Will this motor work for making a long tail? Im afraid that there is going to be too much vibration. Let me know what you think. Thanks, Bobby |
Author: | Woodiebuster [ Fri Jun 24, 2011 7:28 pm ] |
Post subject: | Re: 16 HP home build question |
The 16 isnt a v-twin? |
Author: | scotts98rt [ Fri Jun 24, 2011 7:50 pm ] |
I dont see why it wouldn't work. |
Author: | montrose trapper [ Fri Jun 24, 2011 7:56 pm ] |
It is a used motor out of a mid 90's craftsman mower. Its a 16 hp IC which i thought meant Inline cylender but i could be wrong. This wont cause too much vibration will it? |
Author: | scotts98rt [ Fri Jun 24, 2011 9:04 pm ] |
As long as its a horiz. shaft I dont see what the problem is. Is it a tapered crank? Or straight? Straight you should be able to get a 1in. yoke and be all set. |
Author: | scotts98rt [ Fri Jun 24, 2011 9:06 pm ] |
As for vibration define too much.I have no idea what the IC stands for either. |
Author: | kibb [ Fri Jun 24, 2011 9:20 pm ] |
Industrial/commercial engine. They usually have cast iron sleeves and heavy duty air filters & valves. |
Author: | jp0242 [ Fri Jun 24, 2011 9:29 pm ] |
I have a 16 hp duromax engine from maxtools.com it is a single cylinder motor and it runs fine no more vibration then a honda single cylinder engine i upgraded to it from my 9 hp cause it was such a good deal only like $330 brand new couldnt past it up i can buy 3 of those for the price of one vanguard so far its a great little longtail engine hope this helps |
Author: | SwampDonkey1 [ Sat Jun 25, 2011 12:28 am ] |
Author: | montrose trapper [ Sat Jun 25, 2011 6:10 pm ] |
Thanks for the input guys. I'm gonna give it a run with this one and if it doesn't work I'll have the frame built and might try one of the durostar ones |
Author: | montrose trapper [ Thu Jun 30, 2011 8:20 pm ] |
Alright guys i got the motor running and my next investment is the prop. I mainly run in shallow rivers and in beaver ponds with lots of logs and weeds. My question is what size prop do i need. I was looking at Hill Marinebut im open to other suggestions too. Any help is appreciated guys. Thanks, Bobby |
Author: | scotts98rt [ Fri Jul 01, 2011 5:46 am ] |
Go with the hill, I built 3 so far this month and of the different props we have bought the hill seems to be exactly what I should have bought. Also cheaper than what I paid from ebay.As for the prop size just tell them what size motor you have. For reference, the mudbuddy I used for a pattern was a 13hp with a gear reduction used a 10x10 prop. |
