Longtail Finally Done ! https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=19868 |
Author: | Powerstroke9773 [ Sat Jul 09, 2011 7:38 pm ] |
Post subject: | Longtail Finally Done ! |
I just finished my Longtail tonight ran it in the driveway everything looked good all i gotta do is rig up the kill switch and put in the set screws on the upper bearing and drill a hole for the u joint screws. i do have a question about the lower prop washers where do they fit in the order of things right now i have the cap on then the machined prop nut then a washer then a prop then washer and then the 2 jam nuts im curious if the washers are right or if one goes between the machined nut and cap ? |
Author: | kibb [ Sat Jul 09, 2011 8:03 pm ] |
You have it right. |
Author: | Powerstroke9773 [ Sun Jul 10, 2011 1:06 am ] |
Post subject: | Re: Longtail Finally Done ! |
so the two bronze washers go on either side of the prop it doesnt seem right for that machined prop nut to ride right on the cap like that i would think that there would need to be one there but like ie said i dont know which is right thanks for letting me know that i got it right so it wont hurt the cap having that machined prop nut riding right on it ? |
Author: | kibb [ Sun Jul 10, 2011 5:50 am ] |
Went you set the shaft you need to allow about 1/8" clearance between the cap and nut. |
Author: | Powerstroke9773 [ Sun Jul 10, 2011 11:49 am ] |
so dont tighten the nut to the cap well then what keeps the shaft tight in the housing ? |
Author: | Woodiebuster [ Sun Jul 10, 2011 12:14 pm ] |
bearings, the u-joint holds it from the top. |
Author: | Powerstroke9773 [ Sun Jul 10, 2011 2:52 pm ] |
so its the same on yours woodie 1/8 inch between cap and nut can somebody post a pic for me to look at ? |
Author: | kibb [ Sun Jul 10, 2011 6:57 pm ] |
The yoke and set screw is what holds the shaft in place. Also, the top bearing with a concentric collar. |
Author: | Woodiebuster [ Mon Jul 11, 2011 9:33 am ] |
I'd say its a good bit more than 1/8 on mine. |
