1644 go devil
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=19938
Author:  hookpuller [ Mon Jul 11, 2011 11:24 pm ]
Post subject:  1644 go devil
I have a option to buy a 1644 go devil boat with a 25hp go devil longtail. I have yet to ride in the boat and was wandering what to expect for speed. I know longtails arent built for speed but I would at least like it to plane off. What should I expect fully loaded? (3 guys, decoys, battery, fuel, etc) Is this rig going to plane off with a full load?
Author:  mississippiduckboy [ Mon Jul 11, 2011 11:32 pm ]
Post subject:  Re: 1644 go devil
Yes it will plain out, and I would guess in the 16 to 18 mph range.
Author:  earl33 [ Tue Jul 12, 2011 5:41 am ]
I will guess with that load, 12-16 mph. Alot depends on how much wear the prop has and what prop your gonna run.. And if your running up river or down river has alot to do wit speed.. :)
Get two of ya buddys and take the boat for a test run..
Author:  4Cody4 [ Tue Jul 12, 2011 9:53 am ]
I run a GD 1644 with a 24lt and I don't think you will see 16 mph with that load. When I have 3 guys in the boat including myself with bowfishing gear (platform/lights, generator, extra batteries, cooler, and a bucket with fish in it it will only plane out if the stars align and you re-arrange the weight in the boat. With that said, that is probably more weight than what your decoys will add up to. I don't think the boat will have any problem planing out, but don't expect 16-18 mph out of it. I would bet you will be in that 13-14 mph range.
Sometimes it's tough getting realistic speeds out of people on here, but with the right prop and conditions you may certainly be able to get a bit better speeds than I'm seeing.
Good luck and I hope this helps.
Author:  kibb [ Tue Jul 12, 2011 10:49 am ]
Don't mind MSB, he must be smoking something. 13-14 is about right.
Author:  mississippiduckboy [ Wed Jul 13, 2011 7:58 am ]
Reason I said 16-18 is you dont know how big buddys are, or if boat is hooked up, or prop wear or anything most he could expect in perfect conditions is about 18
Author:  4Cody4 [ Wed Jul 13, 2011 11:15 am ]
I wouldn't hit 18 with 3 people in the boat if there was no gear and everybody was naked and paddling.
Author:  marsh maniac [ Thu Jul 14, 2011 5:42 pm ]
I've got a 1644 gd boat with a 25 kohler go devil longtail. I can assure you that you will not hit 16-18 mph with the load you are talking about. When turning about 3530 or so rpm's with a slightly wore down prop, you will run about 18 mph with a very light load. You'll be running about 13 with the heavy load you are talking about. i run about 15-16 with 2 hunters 2 dozen decoys, 80lb dog, and gear.
Author:  da go get'er [ Thu Jul 14, 2011 6:17 pm ]
i run a 27lt on a 16*44 at work very light load it runs 20mph. Loaded down with 2 passengers, icechest, work equiptment about 150lbs = low teens 13 to 14.
Author:  kibb [ Thu Jul 14, 2011 6:27 pm ]
Author:  GDLT31 [ Sun Jul 17, 2011 11:59 pm ]
Speed ain't everyting,it's about getting there and back safely.
