HELP!! https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=20978 |
Author: | quackhead16 [ Sat Aug 13, 2011 5:03 pm ] |
Post subject: | HELP!! |
I have a homemade long tail with a 9hp Honda. I can't seem to get the top part of the universal joint (on the engine) to stay tight. It continues to slide up?? If anyone could help or has any ideas it would be much appreciated. |
Author: | Powerstroke9773 [ Sun Aug 14, 2011 1:07 am ] |
Post subject: | Re: HELP!! |
if th eu joint keeps sliding up just pull the set screw out drill a hole into the shaft and reset your set screw with loctite |
Author: | garjacker [ Sun Aug 14, 2011 6:02 am ] |
yea that will work and a oversize key will help. btw if you can get it, the loctite green "638" is the best. its made for slip fit put it on the shaft and set screw. |
Author: | scotts98rt [ Sun Aug 14, 2011 11:24 am ] |
I use a collar that I got from my local hardware it slides on before the u-joint and stopped my problems. I think it was like 2-3.00. |
Author: | specgoos1222 [ Sun Aug 14, 2011 12:29 pm ] |
I use square head bolts (at least grade5) and red loctite. Tighten with a breakover. |
Author: | quackhead16 [ Sun Aug 14, 2011 5:40 pm ] |
Thanks for the help guys, it's much appreciated problem is solved! |
