It is currently Sat Jul 12, 2025 9:23 pm
Reply to topic  [ 10 posts ]
 New LT cutting off.
Post New LT cutting off.
I have a new LT that I purchased a couple months ago from a private seller. Its a 6.5 HP gx200 longtail that had only been started but not ran in water when I purchased it. It sat from January 2011 to July 2011 and was not winterized. The motor started and ran well the first couple times out. Recently it has been cutting off under power, usually when i'm at full throttle the motor just boggs down. First time it happened I restarted it right away with no problems. Last time I let it sit before restarting and it wouldn't start. It will go at full throttle out of the water but boggs down at full throttle when underwater pushing weight. What could be the problem?
Wed Aug 31, 2011 3:48 pm
Post Re: New LT cutting off.
Clean the carb
Wed Aug 31, 2011 4:29 pm
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Wed Aug 31, 2011 7:41 pm
Well I got the tank 1/4 full and put "extreme" the cleaner gas from the gas station and put that in there. It went through the first tank fine. Then I fill the whole tank with the cleaner gas and this problem occurred while going through that tank.
Wed Aug 31, 2011 7:44 pm
Or check ur spark plug an wire
Wed Aug 31, 2011 7:46 pm
Your coil may be going out.
A new coil, plug wire, and boot is about 30 bucks.
Wed Aug 31, 2011 8:15 pm
Clean ur carb real good ditch that fancy ass gas
Sea foam is thd best cleaner I've found
Wed Aug 31, 2011 8:56 pm
yea some times those metal tanks will rust and clog the carb. clean carb and use an inline filter for gravity fed carbs.
Thu Sep 01, 2011 5:02 pm
My brother and I build small longtails and I would be willing to bet that if your motor continues to start and run when not under load that its not a motor problem. Depending on what size prop you have and load you are pushing your motor may need the cavitation plate adjusted so that its not running too deep. If its running too deep its killing the motor because it doesn't have the torque being a 6.5 hp motor. Bend the cavitation plate down towards the prop to create lift and get the prop closer to the surface. This may fix your problem. Good luck.
Tue Sep 06, 2011 7:44 pm
My guess is bad gas. I've had the same problem when water gets in the gas...
Wed Sep 07, 2011 7:47 am
Users browsing this forum: No registered users and 40 guests
