It is currently Sun Jul 13, 2025 9:35 am
[ 4 posts ] |
Jw261
Joined: Sat Oct 22, 2011 12:20 pm Posts: 96 Location: Lower Alabama
 Squeaking at prop
I have a 16 hp go devil lt that I just bought this summer. Never had a chance to do much more than crank it up since I bought it. Finally got it on a boat and was just out getting it running after it hasn't started in a couple months. It's squeaking from the prop. I don't remember it doing that before. Is that normal? I greased it per the manuals instructions before running it. Seems like it lessens or goes away all together at higher rpms.
Sun Oct 23, 2011 11:44 am |
goday34
 Re: Squeaking at prop
Sounds like it's noise would be coming from the seals near the prop I just remove the shaft from 23hp the shaft was groved at the seal area
Thu Oct 27, 2011 9:59 am |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
could be the scraper seal. its a hard plastic.
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Thu Oct 27, 2011 1:20 pm |
Bayport
I had the same thing. The nice folks at GD told me this: SPRAY WD 40 AT SHAFT AND LOWER SEALS FLANGE BUSHING MAYBE VIBRATING
Sure enough, that stopped it.
Tue Nov 08, 2011 8:44 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 33 guests |
