23 vanguard rpms? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=23791 |
Author: | clemsonmmt [ Mon Nov 07, 2011 6:55 am ] |
Post subject: | 23 vanguard rpms? |
i am curious as to what my 23 go devil should be putting out as far as rpms? right now with 2 people in my 14' xpress it is normally around 3570 at top speed. this seems a bit low to me but the motor runs fine and has never had an issue. any quick ways to get more rpms out of a motor like mine? |
Author: | Glades Ranger [ Mon Nov 07, 2011 10:31 am ] |
Post subject: | Re: 23 vanguard rpms? |
I am almost sure there are many posts on this subject-use the seach function. I am also relatively new to here but you can gain rpm's by adjusting the throttle. I have set my 27 Kohler longtail motor to 4150 rpms out of the water; this translates to around 3800 in the water under load. If you are getting 3570 in the water under load this is not too far from max. I know some are skeptical but I have noticed better performance after using synthetic oil and grease. Must be a reason the mfg.'s recommend synthetic after initial motor break in. |
Author: | Woodiebuster [ Mon Nov 07, 2011 5:38 pm ] |
sounds normal. |
Author: | clemsonmmt [ Mon Nov 07, 2011 9:22 pm ] |
thanks for the info guys |
Author: | JGUT [ Fri Nov 11, 2011 3:07 pm ] |
you can adjust your governer spring and pick up a little more. i tweeked mine and ported the intake and i get 4100 out the water and 3850 two guys, dog, and hunting gear in the water wot. |
