It is currently Tue Jul 08, 2025 4:25 am
[ 4 posts ] |
Cavitation plate or Adjustment screw?
Buzz Killington
Running a 20hp GDLT -
I'm supposed to be seeing the cavitation plate operating 2-3 inches below the surface at full throttle - however, its getting pulled WAY lower than that - almost 12-14 inches.
My cavitation plate has the dealer lift to it (up) and my adjustment screw I haven't touched because I've had to grind out of a few predicaments in the past.
Simple solution I would think is to bend the cavitation plate downwards...
Its possible that all i need to do is raise the adjustment screw on the transom (that limits the drop/rise to the motor while in the water) but I was under the impression that you don't want the adjustment screw to be touching the motor at full throttle - while still allowing room to dig in when required.
Advice?
B. MacDonald
Tue Jan 10, 2012 8:33 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: Cavitation plate or Adjustment screw?
bend your cavitation plate down
_________________ You have your whole life to be an idiot, take a day off!
Tue Jan 10, 2012 8:41 pm |
Buzz Killington
Like I said - easy solutions
Thanks DDB
B. MacDonald
Tue Jan 10, 2012 9:06 pm |
duckduckboom
if you go to far bend it the other way. no harm no foul
Tue Jan 10, 2012 9:07 pm |
[ 4 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 32 guests |
