| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| trailering! https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=25502 |
| Author: | critch5 [ Thu Jan 05, 2012 8:18 pm ] |
| Post subject: | trailering! |
Unfortanately i have a polarkraft 1448 boat and it has the dumb sunk down transom...decent boat...rather have a flat bottom than the mod v...cant swim shaft into boat...any one have the same problem and how did u strap the handle down...had 2 straps break just wondering for ideas...went to see about a trade on an alumacraft and i guess they are like gold because they want 1800 for bare boat and only give me 1000 for my boat and johson motor.... |
| Author: | critch5 [ Thu Jan 05, 2012 8:35 pm ] |
| Post subject: | Re: trailering! |
sorry cant swing the shaft into the boat because of the uneven transom |
| Author: | woodduck224 [ Thu Jan 05, 2012 8:37 pm ] |
When I had a long tail on my old boat. I put an eyebolt in a rib on the floor and used a turn buckle. worked great |
| Author: | marsh mule [ Thu Jan 05, 2012 8:59 pm ] |
When I had a long tail, mine had a bracket coming from the trailer to hold up the shaft that just had quick connects to take on and off... |
| Author: | Glades Ranger [ Fri Jan 06, 2012 4:35 am ] |
EVen though my 27 MB LT has the swivel feature, I still trailer it the old way. GD's manual recommended a rope tieing down the handle, the rope stretching across the gunwales just like your regular boat strap. I use two bungees to a couple of metal clamps that are screwed into the rear pods; I also use another two bungees on the handle and these have clip ends that are positioned in a gap between the welded in rear floor and supporting ribs. The "failsafe" is the boat strap. |
| Author: | indawoods [ Fri Jan 06, 2012 11:26 pm ] |
Use a strap as your primary and a rope with a carabiner to a shackle on a floor rib as your back up. Two tie downs = peace of mind. |
| Author: | Dixie [ Sun Jan 08, 2012 6:24 am ] |
Because of my blind, I had to make a vee block then run the rachet strap around the seat on either side of the block and wrap around the handle. The motor is held tight and dont move. |
| Author: | MeatWagon [ Sun Jan 08, 2012 7:22 am ] |
get a bigger strap |
| Author: | da go get'er [ Sun Jan 08, 2012 8:12 pm ] |
