Cavitation plate or Adjustment screw? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=25659 |
Author: | Buzz Killington [ Tue Jan 10, 2012 8:33 pm ] |
Post subject: | Cavitation plate or Adjustment screw? |
Running a 20hp GDLT - I'm supposed to be seeing the cavitation plate operating 2-3 inches below the surface at full throttle - however, its getting pulled WAY lower than that - almost 12-14 inches. My cavitation plate has the dealer lift to it (up) and my adjustment screw I haven't touched because I've had to grind out of a few predicaments in the past. Simple solution I would think is to bend the cavitation plate downwards... Its possible that all i need to do is raise the adjustment screw on the transom (that limits the drop/rise to the motor while in the water) but I was under the impression that you don't want the adjustment screw to be touching the motor at full throttle - while still allowing room to dig in when required. Advice? |
Author: | duckduckboom [ Tue Jan 10, 2012 8:41 pm ] |
Post subject: | Re: Cavitation plate or Adjustment screw? |
bend your cavitation plate down |
Author: | Buzz Killington [ Tue Jan 10, 2012 9:06 pm ] |
Like I said - easy solutions Thanks DDB |
Author: | duckduckboom [ Tue Jan 10, 2012 9:07 pm ] |
if you go to far bend it the other way. no harm no foul |
