JerseyDutch
 Shaft Prices
What seems to be a typical price for a new shaft? I have a bog hog lt. Their website sells shafts for $120. Using the search function on here, I saw around $100 mentioned. I called a local machine shop to get a quote for machining my own shaft. They said around 3 hours to set up the lathe and mill to cut the threads and keyway at $65/hr rate. This makes the bh shaft seem worth it but 3 hours seems like a long time to cut threads and a keyway? Is this on par or should I keep looking? I had a hard time just finding a shop that would do it/offer a quote. Most shops around here seem to only do production work and no custom stuff. As a comparision, I found that bt sells their 71 inch shaft for $88. So many projects piling up now....It's just time and money, both of which I seem to be running out of
Mon May 21, 2012 7:59 pm |
Quackkillz
Joined: Sun Dec 04, 2011 4:57 am Posts: 535 Location: Bottom of da boot
 Shaft Prices
Go devil shafts are $62 if I remember correctly.
_________________ 1648 weld bilt being followed by a 35 gtr
Mon May 21, 2012 8:08 pm |
Buzz Killington
 Re: Shaft Prices
B. MacDonald
Tue May 22, 2012 7:57 am |
JerseyDutch
 Re: Shaft Prices
Tue May 22, 2012 6:16 pm |
yovi91
 Re: Shaft Prices
i just bought a shaft from go devil last week and it ran me 80$ plus shipping
Tue May 22, 2012 8:00 pm |
Buzz Killington
 Shaft Prices
B. MacDonald
Wed May 23, 2012 5:15 am |
bobbyjober
Joined: Sun Aug 08, 2010 3:28 pm Posts: 546 Location: St. Martinville, La
 Re: Shaft Prices
Hold up you said you have a "no name" longtail? I read you have a boghog, which is a name brand, last time I checked. So stop being a dumbass or a cheap ass and just buy the boghog replacement shaft, PLEASE for the love of GOD do it!!!!!!!!!
_________________ 1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
Wed May 23, 2012 7:48 am |
Woodiebuster
 Re: Shaft Prices
If you would read a little before you opened that cocksucker of yours you would know Bog Hog went under. Who is the dumbass now?
Wed May 23, 2012 11:22 am |
scottfarm
 Re: Shaft Prices
I had to pay $120 plus shipping($138 delivered to door) from mudbuddy.
Wed May 23, 2012 5:32 pm |
JerseyDutch
 Re: Shaft Prices
Wed May 23, 2012 5:46 pm |
JerseyDutch
 Re: Shaft Prices
Wed May 23, 2012 5:50 pm |
bobbyjober
 Re: Shaft Prices
my time is valuable, so all the time you wasting being a cheap azz, you could have been back and running already. To each his own, but i bet a bog hog shaft would be easier , simple fact it is made for the frame. And by the way Woodie, you been pretty stupid lately, maybe you need some pussy idk. Go research Bog Hog more Woodie and you will find they still are very much in business. These statements and words are not intentional meant to hurt or offend anyone, so please read with warning. Thanks, Bobby
Thu May 24, 2012 5:58 am |
JerseyDutch
 Re: Shaft Prices
Your time can't be that valuable if you come on this site, read posts, and then make useless comments.
I understand that buying a shaft from bog hog would be the easiest route, but that wasn't my question. I wanted to know how much people pay for a shaft from other companies or from local machinists. My time is valuable, but so is money when you don't have a lot to throw around. This is a project that I am in no hurry with. I have until duck season to work all the kinks out.
I am just tossing ideas out there for some input. I don't mind taking my time and saving some money on this project.
Thu May 24, 2012 7:31 pm |
bubba777
 Re: Shaft Prices
What material is the shaft made out of? Don't want it to soft get me the material I will cut it for you buddy
Thu May 24, 2012 8:07 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
 Re: Shaft Prices
Just ordered shafts from local metal supplier, $26 a piece. Local machine shop is keying/ threading for $175 for 4 shafts.....
_________________ If I can't Break it, it can't be Broke.............................
Fri May 25, 2012 6:49 pm |
Pintail58
Joined: Fri Feb 06, 2009 8:17 am Posts: 578 Location: Lafayette , La on da outside
 Re: Shaft Prices
What type metal? Is it a hardened steel or plain cold roll?
_________________ Shoot 1st ask later 14' leaker w/ 20hplt Shootin time Teal Season 2010 http://xrl.in/64aw #countdown
Thu Jul 26, 2012 8:58 am |
QuackStacker5253
Joined: Thu Jul 28, 2011 6:47 am Posts: 281 Location: Longview/Tyler Tx
 Re: Shaft Prices
I just bought 2 and had them machine for key way and threaded for $75
_________________ 1748 WC Custom 27 mini
Thu Jul 26, 2012 1:20 pm |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
 Re: Shaft Prices
For small Hp, 10 or less, Cold rolled 1018 will probably suffice. Anything bigger, I like to use 4140 pre hard turned ground and polished or 17-4 H1150 . The 17-4 is usually slightly oversized for bearings, so you do have to do some work with emery cloth or take a light pass on the lathe to get a good transitional fit.
Fri Jul 27, 2012 12:05 pm |
