It is currently Tue Jul 08, 2025 1:26 am
Reply to topic  [ 27 posts ]
 Crawfish Tail??
Post Crawfish Tail??
Just wondering what's the advantage of the crawfish tail over a regular GDLT?
Wed Mar 07, 2012 7:27 pm
Post Re: Crawfish Tail??
Shorter shaft I think
1850 & 36pd
Thu Mar 08, 2012 3:01 am
Yup
Shorter shaft length
B. MacDonald
Thu Mar 08, 2012 6:09 am
I know the shaft is shorter. I was wondering what the advantages and disadvantages of the shorter tail.
Thu Mar 08, 2012 1:15 pm
The advantage is, its shorter. The disadvantage is, its shorter.
Thu Mar 08, 2012 2:31 pm
Thu Mar 08, 2012 3:22 pm
If you running trees and stumps, the longer the better. Trust me.
1748 X-Series pushed by 36PD with MarshMellow Exhaust
Poule Deaux Crew
Thu Mar 08, 2012 4:46 pm
its a cunt hair easier to drive, not worth the lost reach IMO.
Thu Mar 08, 2012 6:14 pm
depends on how tight the trees are. My cousin and I both run 17*38 boats with a 23gdlt. open water his boat(crawfish model) is slooooow but it is much easier to turn around in the narrow ditches with trees. Mine is faster by about 3 miles an hour. His also turns alittle sharper
17*38 Klibert 23GDLT
Thu Mar 08, 2012 8:25 pm
Thu Mar 08, 2012 8:28 pm
lets go!
Thu Mar 08, 2012 8:32 pm
Don't some of the crawfish models have a gear reduction box that allows you run a bigger prop and push more water?
Fri Mar 09, 2012 8:55 am
Fri Mar 09, 2012 10:08 am
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Fri Mar 09, 2012 12:13 pm
Fri Mar 09, 2012 12:45 pm
This is exactly what it looks like
Fri Mar 09, 2012 1:12 pm
The gear reduction is in the crankcase, not the frame.
Fri Mar 09, 2012 4:26 pm
It's not in the crankcase. It a whole different animal. It's an add-on that's clearly shown in the picture.
Fri Mar 09, 2012 6:52 pm
So, you can take that gearbox off and have a direct drive engine?
Fri Mar 09, 2012 8:56 pm
I never have but by the looks of it you can. You would have to open the gearbox to do it. My guess is that there is a gear with a keyway and retaining bolt coming off the mainshaft.
Fri Mar 09, 2012 9:12 pm
Here ya go. I forgot about the centrifugal clutch. By the looks of it, the clutch w/gear goes on the drive line like I said. Keyed then bolted through the end. Output shaft on the gearbox and engine should be similar.
Fri Mar 09, 2012 9:25 pm
This prop actually measured 9 3/4" but you can't tell with the angle of the pic. It's worn a lil and most likely was a 10". I'm not sure of the pitch without taking it off. This is a 9 hp motor.
Mon Mar 19, 2012 11:52 am
There is a 10X12 three blade on my buddies.
Sun Apr 08, 2012 6:51 pm
So we can all agree Godevil had the first longtail with gear reduction and neutral. Even the first mudmotor with neutral, being the reduction gear has a neutral at idle. Crawfisherman favored this longtail for that reason . I know of numerous commercial fisherman still using the 9hp crawfish model to this day. I seen people hang chains off the front of boat as to keep boat still at idle to raise crawfish traps.
Tue Apr 10, 2012 9:00 am
Profile YIM
This one has been has been under water for weeks, then flushed and ran for years. I am reduilding it know because it ran for years with bent prop and raddled everthing lose. These are some badass motors. Not real fast but badass and dependable.
Tue Apr 10, 2012 6:27 pm
Post Re: Re: Crawfish Tail??
1432 fiberglass inboard with an18 vanguard gettiung where i need to go slowly
F_CK Y__
Would you like to buy a vowel?
Tue Apr 10, 2012 7:18 pm
You can get the smaller engine variety on *bay; search for reduction gearbox.
Tue Apr 10, 2012 8:11 pm
Users browsing this forum: No registered users and 30 guests
