It is currently Sun Jul 06, 2025 7:20 pm
Reply to topic  [ 101 posts ]  Go to page 1, 2, 3  Next
 Converting my boat for longtail
Post Converting my boat for longtail
So I went out on my buddies mud boat about three months ago and after that decided I wanted one. So working with what I got I decided to convert my 1648 bass tracker to a mud hull.
This is what I started with:
And work began
Ordered some new paint and started putting it on today
Tomorrow I'm finishing painting and adding gator glide to the bottom. Also have tan camo hydroturf coming in on Wednesday.
This is what's going on. A 27hp Beavertail longtail.
Hopefully have it in the water next weekend!
Sat Mar 24, 2012 8:03 pm
Post Re: Converting my boat for longtail
Let us know how it does
Sun Mar 25, 2012 8:51 am
After two coats of gator glide. One left.
Sun Mar 25, 2012 9:50 am
Looks like it has a lot of potential! are you going to keep the consol steer?
Mon Mar 26, 2012 10:49 am
Nope gave it to my dad. It's all open floor. Camo hydroturf coming in tomorrow and it's all finished!
Mon Mar 26, 2012 11:45 am
Nice, I like how open the boat is. Are you going to put a floor in?
Tue Mar 27, 2012 5:25 am
I'm putting in a 1/2 plywood sheet that I treated myself. Covering it with tan camo hydroturf. Using one of the old live wells as a seat.
Tue Mar 27, 2012 5:27 am
Looks great!
B. MacDonald
Tue Mar 27, 2012 5:40 am
Swampthing, I would suggest an aluminum floor rather than the plywood. The wood will work but be heavier and eventually rot. I would go with at least .090 alum. You can add some insulation/flotation under the floor and between the ribs to make a snug quiet fit. You can put the hydroturf over the alum and the be good. Just my two cents.
Tue Mar 27, 2012 2:14 pm
1748 X-Series pushed by 36PD with MarshMellow Exhaust
Poule Deaux Crew
Tue Mar 27, 2012 3:29 pm
I would but didn't have the budget, it's gonna be wood for a little. When it rots I'll go with aluminum.
Tue Mar 27, 2012 5:29 pm
Putting motor on tomorrow. Testing Saturday.
Wed Mar 28, 2012 5:00 pm
Looking good!!!
Wed Mar 28, 2012 5:08 pm
Ok, I know about the budget thing, I bought hydroturf "closeout" pieces as well because that stuff is as expensive as the aluminum- well, almost. I guess too late to say spare the hydroturf on the wood, but you apparently glued it on already. I bought a 4' x8' sheet of aluminum .090 gauge back in 2004 for around $75. I imagine that has gone up a bit. I did the bow with the dark grey diamond groove pattern and ordered the floor piece in the tan camo. Don't care about uniform color, it's my duck boat, not a bass boat. :mrgreen: Let us know about the gator glide- I only used one coat of the steelflex (fasco corp.) and it is great. Looks like you'll have plenty of room to put the battery and/or gas tank up front if need be for balancing the load. Did the BT cavitation plate include a "trim tab" on the trailing edge to adjust planing depth? Or do you have to bend the whole plate? I know you must be excited. I figure if you tweak the throttle after break-in period, you'll realize about 4200 rpm out of the water and you should be close to 20 mph by yourself. I figure your 1648 rivetted hull should be lighter than my welded 1648 .100 Grizzly hull? Don't forget to wear your kill switch lanyard! I would also recommend those "bird bucket" seats (Cabelas) for seating. All the best!
Thu Mar 29, 2012 5:40 am
Sorry, but I must add that I have always enjoyed DIY, specially on my duck boat. You get more satisfaction, not to mention saving $$, on this type of work. Does that hull have the gunwale T-bolt channel? It has come really handy on mine- you don't have to buy expensive T-bolts either- you can drill an access point on either end and insert full head 1/4" diameter carriage bolts and make it work. I've added a bunch of items with this feature and they are out of the way and you don't have to drill through the hull. Give us the full field report after the "maiden voyage"!!
Thu Mar 29, 2012 5:45 am
Thanks man. Yeh it totally looks like a brand new boat. I'm real excited about taking it out. I think it only had the bend tabs on the side for the motor.
I have def enjoyed building this myself. I can make it how I want it and save some green. Planning on taking it out Saturday and Sunday. First time driving a mud motor!
Thu Mar 29, 2012 6:12 am
Ready for tomorrow
Fri Mar 30, 2012 6:36 pm
Nice job!
1850 & 36pd
Fri Mar 30, 2012 7:12 pm
Sharp looking rig
Fri Mar 30, 2012 7:25 pm
Thanks guys. The only thing I'm worried about is I over tightened the clamp bolts and the are crooked now. Think they will be alright? There is still one 3/8 bolt going through transom
Fri Mar 30, 2012 7:30 pm
Guess you'll find out tomorrow ;)
B. MacDonald
Fri Mar 30, 2012 8:11 pm
You really r a buzz killington lol
Fri Mar 30, 2012 8:54 pm
you'll be fine. I guess you already know about watching for logs and stumps with those horizontal braces? Over time, the bottom of your boat will 'washboard' and lose performance. that light hull will haul ass.
Sat Mar 31, 2012 1:00 am
B. MacDonald
Sat Mar 31, 2012 6:32 am
B. MacDonald
Sat Mar 31, 2012 6:34 am
Boat did great but I can't get the damn prop to stay in the water.. What did you guys use to bend the cap plate up? The Beavertail has tabs on both sides I'm guessing bend those up?
Sat Mar 31, 2012 8:26 am
No not the side tabs, the flat part above the prop
fiat justitia et pereat mundus
1642 WeldBilt Crawdad/ 23hp S.W.O.M.P
viewtopic.php?f=18&t=27507
viewtopic.php?f=18&t=27513
Sat Mar 31, 2012 9:41 am
I bent the sides up bc I couldnt get the flat part to move. Heading back to lake
Sat Mar 31, 2012 10:19 am
Use a large crescent wrench. Tighten it up just enough to slide onto the tab, then bend it up or down. It doesn't take much.
Sat Mar 31, 2012 10:51 am
I found the sweet spot. Just happens now when I hit a wave or something it'll pop up. Rode well though. Already hit my first stump lol.
Sat Mar 31, 2012 12:21 pm
Sat Mar 31, 2012 1:34 pm
good deal, i hit one in mine too with less than 5 hrs on my new rig. adds charactor
Sat Mar 31, 2012 3:23 pm
Looks Great!
14'36'' Jon Boat 23 hp GDLT
Sat Mar 31, 2012 3:40 pm
Thanks guys. It's nice to see the hard work pay off.
Sat Mar 31, 2012 4:31 pm
an 18 inch pipe wrench works great on cav plates, fyi.
any gps speeds? DETAILS MAN!
Sat Mar 31, 2012 7:02 pm
I still need to buy a gps. I imagine atleast 18 with my gf and I with a collet and tackle.
Sat Mar 31, 2012 7:41 pm
Cooler*
Sat Mar 31, 2012 7:42 pm
Looks like the hard work paid off. Good job on the boat.
B. MacDonald
Sun Apr 01, 2012 6:30 am
K new problem. Now the boat shuts off after awhile like it stop getting fuel. I shortened the line a little and played with it until it got fuel again and then it ran. Could this be bc everytime I stop to fish I close the vent on the fuel tank and open it when I'm ready to move?
Sun Apr 01, 2012 11:44 am
Every day I'm paddlin'
1848 Gatortail boat and 37 efi GTR.
Sun Apr 01, 2012 11:55 am
Users browsing this forum: No registered users and 60 guests
